leaning on rear drivers side help
Old Aug 18, 2005 | 06:16 PM
Vitamin-SC's Avatar
Vitamin-SC
Default leaning on rear drivers side help
his probably has come up but i couldn't find any info, Soo here goes: My 95 sc 400 seems to be leaning in the rear about an 1.5"-2" on the drivers side i was wondering if any others have had this problem and what were there findings I wanted to ask before i took it to my local alignment/ frame suspension shop need some inside info so i wont get shafted my some replacent mechanic that just replace parts until they get it right any help or insight is greatly appreciated
greg
Old Aug 22, 2005 | 05:26 PM
CantSeeMe's Avatar
CantSeeMe
greg
What kind of setup are you running? Did you recently have any changes to your suspension? Was this a sudden drop?
Old Aug 30, 2005 | 03:38 PM
Vitamin-SC's Avatar
Vitamin-SC
Default stock set
haven't done anything everything tock as far as suspension didnt really notice until I changed rims 18x8 front 18x9 rear 275 35 198 in rear no other changes I was thinking bad shock or spring but not sure
Old Aug 31, 2005 | 06:23 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
I'm leaning toward a blown shock.
Old Aug 31, 2005 | 11:09 AM
pilip99's Avatar
pilip99
i seem to be having this problem, but i think its common after Eibach springs are installed
Old Sep 1, 2005 | 09:03 AM
RaynArt's Avatar
RaynArt
seems to be. for me i think its the eibachs that did it, my passenger side is a tad higher than the driver but i'll eventually just buy some new springs cause i am satisfied with the kyb's.
anyways for this case it sounds more like a blown shock if its specifically one corner of the car.
Old Sep 1, 2005 | 01:26 PM
howiedoit's Avatar
howiedoit
i'm having a similar problem. my whole drivers side is lower by well over an inch. actually, it seems like it's not just that the drivers side is lower. it appears to me that the passenger side has raised up a tiny bit. i just noticed it recently. i compared with some older pictures of my car and it didn't used to be like this.
i'm planning on taking out the spring/shock assembly parts next week. i'm hoping it's just a blown shock. i'll update with info when i figure out the problem. unless someone else knows what the issue is?
Old Sep 1, 2005 | 01:34 PM
3rdelement's Avatar
3rdelement
yeah ive spoken recently to many suspension shops. they recommend switchin out to a kyb or tokico(or aftermarket struts) they can handle not being fully extended during normal driving. the stock struts seem to have a bad habit of giving up when lowering shocks are installed. :-\ it sucks but gives you a great excuse to increase your handling response......its just gonna cost you another 3 or $400 most likely.
Old Sep 1, 2005 | 01:37 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
But he's running stock suspension.
Old Sep 1, 2005 | 03:40 PM
3rdelement's Avatar
3rdelement
sorry i must have misread. i saw Eibach springs there somewhere. if you have lowering springs the strut is dead because of the fact it wasnt made to ride nonextended for long periods of time..
if you are running stock....i agree the strut is blown. but also check your springs.
i have this problem on my back wheels and its because my struts and springs are worn out.
Old Sep 10, 2005 | 11:23 PM
Jimbo2828's Avatar
Jimbo2828
BlaznSC4 he had the car lower with eibachs and tokico blues the passenger side was still lower then the driver side. it wasnt blown shock jsu could figure out what was the problem. so he jus went to autozone or something and brought some shock shackles and compress a few coils of the spring to balance it out.
Pxnda
Apr 29, 2014 06:32 PM
csr
Suspension and Brakes
Oct 9, 2002 09:55 PM
