Tokico and Eibach
Old Sep 2, 2005 | 10:04 AM
SharpCreas's Avatar
SharpCreas
Default Tokico and Eibach
Heys fellas, I've been searching this forum for months now and finally came to the conclusion of which susp. setup I want. I think I'm going to go with the Tokico blues and Eibach pro. The reason I've choosen this is because I hear to many compliants about the Camber, rubbing,and etc if I go lower than a inch. Ok, that being said, Is there ANYTHING else I need to know about the tokico blues and eibach setup before I purchase these????? I heard of cluncking noises which bothers me alittle but is there anything I can do or buy from eibach to stop this from happening besides buying a rubber tube and DIY(which I heard is not to reliable). BTW, I'll be running 245x35x19 on the fronts and 275x30x19 on the rear unless you guys have a better opinion. I was thinking about 20"s but alot of you guys in the forum dislikes the look of 20's on a SC400(not saying I'm a follower but I don't want to take a chance and purchase something that looks bad). Please fellas, any comments or suggestions will be appreciated to the FULLEST as to I'm going to buy then within the next week..
Old Sep 2, 2005 | 06:04 PM
jacques's Avatar
jacques
Your setup sounds fine, you've done your research . I might go with a different brand of springs though if your worried about the clunk (tein, espelir)
Old Sep 2, 2005 | 10:28 PM
SharpCreas's Avatar
SharpCreas
But if I go with teins or espelir, I have to get a camber kit. Anybody knows if Eibach corrected this clunking problem with there springs
Old Sep 2, 2005 | 11:01 PM
howiedoit's Avatar
howiedoit
I've been able to get within factory alignment specs (although still slightly negative) with my Espelir springs and no camber kit.
Old Sep 10, 2005 | 11:27 PM
Jimbo2828's Avatar
Jimbo2828
do you guys think that the eibach springs plus tokico are lower enough??? cause i jus bought a set of wheels 18's and i really need to lower right after i put on the wheels. i have a set of eibachs but with one coil cut off on the front springs and im really afraid it might be way toooo lower
HardBoiler
Suspension and Brakes
Jul 20, 2007 10:37 AM
ikankoi
Jul 26, 2004 10:14 AM
NAZTY97
Oct 27, 2002 11:42 PM
johnsc400
Aug 2, 2002 05:56 PM
CDALTON
Apr 11, 2001 08:16 AM
