Reverse Gear Not Working!?!?! Code Red!
Old Jul 1, 2001 | 04:49 PM
sxys_sc4's Avatar
sxys_sc4
Unhappy
So my dad, a mechanic ofcourse, changed my transmission fluid BUT when we were about to test drive it, the REVERSE GEAR is NOT working!?!?! But when I put it on DRIVE, it works......What's wrong?? Someone please help me!!!
sxys_sc4
Old Jul 1, 2001 | 05:22 PM
tek619
Guest
Posts: n/a
What kind of car is it? Year?
What type of fluid did you use? Dexron II or type T-IV?
Was it just a simple drain or did you remove the tranny pan?
A simple drain will require a little more than 2 quarts in order for it to be in normal range. If you removed the tranny pan, it usually takes close to 4 quarts.
Old Jul 1, 2001 | 05:30 PM
CmputerWiz's Avatar
CmputerWiz
This happened to me once before on a different car. I changed the tranny filter, and one of my gears quit working. It ended up being some crap that got caught in one of the small valves in the transmission, changing the pressure, and not letting it switch gears.
Hope this helps!
SR
Old Jul 1, 2001 | 07:06 PM
sxys_sc4's Avatar
sxys_sc4
Default THANK YOU
tek619
1. It's a 92 Lexus SC 400
2. I used the Type T IV ATF
3. I believe my dad removed the tranny pan because he had to replace the red silicon (gasket) that sealed it.
I'm not sure if he put the whole gallon but I'm going to find out right now......I'll let you know what happens...Do you have any other suggestions???
PS: Thanks tek619 & ComputerWiz....
Old Jul 1, 2001 | 07:10 PM
CmputerWiz's Avatar
CmputerWiz
No prob! Anything to help another member...or at least to try.
SR
Old Jul 1, 2001 | 07:15 PM
sxys_sc4's Avatar
sxys_sc4
Default help...
ComputerWiz: So what did you do to get the gear back to working?
tek619: I just found out that my dad did put the whole gallon in there...What else can I check?
Old Jul 1, 2001 | 07:22 PM
CmputerWiz's Avatar
CmputerWiz
Ended up having to take the thing back apart, and cleaning out all the pinhole valves and such in the tranny. If it's something like that, your dad would know how to clean them out. Maybe...many mechanics won't mess with auto-trannies, they're a pain in the ***!
SR
Old Jul 2, 2001 | 01:00 AM
whitediamond's Avatar
whitediamond
Default 1 gallon!!!
! gallon is twice the amount you need if you just dropped the pam .Whether you used the oil drain bolt or dropped the pan the same amount of fluid is required which is a tad over 2 quarts. If you put 1 gallon in there then of course you will have trans problems. Also while the pan was off, a remote possibility is that one of the valve electrical connectings got loose.
Old Jul 2, 2001 | 11:46 AM
sxys_sc4's Avatar
sxys_sc4
Thumbs up TO ALL YOU SINCERE GUYS
After everyone's feedback, "I" finally got the reverse gear to work. It was ALL just a matter of having the "normal operating temperature"!?!?! How embarassing is that. And you "Girls...." (ha-ha) But yeah, 1 gallon seemed to work okay BUT I hope I don't get any problems like you said whitediamond. *Crossing my fingers*
One grateful clublexus member,
-sharon-
Old Jul 2, 2001 | 11:48 AM
sxys_sc4's Avatar
sxys_sc4
Cool SWEET!
ComputerWiz...
Just wanted to say "You got a SWEET house!"
Old Jul 2, 2001 | 12:08 PM
CmputerWiz's Avatar
CmputerWiz
Thanx
Maybe I'll have to post some more pics of it somewhere...the inside kicks ***. Spiral staircase and 41ft ceilings. It's a loft design. I got an awesome deal on it, so I couldn't pass it up.
SR
Old Jul 2, 2001 | 01:12 PM
sxys_sc4's Avatar
sxys_sc4
Smile ONLY IN North Carolina...
Yeah, post more pictures! Your house is so isolated. How far away is the next house? Is it scary at night? I could've sworn it looked like those horror movies ya kno? (ha-ha). Only if I could have a house like that here in L.A. But that won't happen until who knows when.
sxys_sc4
92 SC 400
Old Jul 4, 2001 | 12:37 PM
CmputerWiz's Avatar
CmputerWiz
Default Re: SWEET!
Originally posted by sxys_sc4
ComputerWiz...
I put up some more pics of it like you asked! Go back to that same page, and click the link to it under the first picture of it.
SR
Old Jul 4, 2001 | 06:28 PM
sxys_sc4's Avatar
sxys_sc4
Thumbs up TWO THUMBS UP
Niiiiiiiiiiiiiiiiiiiice STEVE! I don't know what else to say EXCEPT niiiiiiiiiiice
Take care
4uhaterz
Mar 15, 2011 10:03 AM
Lexmex
RX - 1st Gen (1999-2003)
15
Oct 20, 2010 08:07 AM
damon
Maintenance
Mar 26, 2008 06:28 PM
Jugg_head
Sep 27, 2006 06:10 AM
