check engine after bfi build
Old Jul 25, 2005 | 10:21 AM
white ice's Avatar
white ice
Default check engine after bfi build
problem solved. thanks jpimportz
Old Jul 25, 2005 | 12:35 PM
sonyman's Avatar
sonyman
Do you mind posting what the solution was, in case someone else has the same issue?
Scott
Old Jul 25, 2005 | 12:39 PM
white ice's Avatar
white ice
the problem was after my bfi was installed the engine light came on. what had happened was i had removed the maf sensor, the air box and everything. i had forgot to turn the wheel all the way to the left before i turned the car off so i could get the headlight out. when i turned the car on to turn the wheels, it on it kicked on the light.
the solution was to reset the ecu. hope this helps
Old Jul 25, 2005 | 12:48 PM
Carbon J's Avatar
Carbon J
Glad the problem is solved, next time remove the airbox from the MAF. Leave MAF alone, delicate piece of equipment.
Old Jul 25, 2005 | 12:52 PM
white ice's Avatar
white ice
i took the maf off the airbox when i was cutting it, but it was all unplugged when i had to turn the car on to turn the wheel, thats when the light occured
fleshnbone
Jun 17, 2012 10:39 PM
SGMIS3
Sep 14, 2011 01:05 PM
saiyanL4
Mar 29, 2009 05:33 PM
VW_Vanagon
Mar 22, 2009 07:20 AM
