Weird A/C Problem
Old Jun 15, 2005 | 06:56 AM
ltbong's Avatar
ltbong
Default Weird A/C Problem
Hello,
I've searched the forums extensively for solutions to my problem and am still not sure what the problem is.
The other day when starting the car, when I turned on the A/C the battery light on the dash and the power steering became erratic. When I turned the wheel it would just fight me. As soon as I turned the a/c off the battery light went off and the power steering was fine again. If I turn the a/c on while on the freeway it usually works fine but sometimes the a/c light will start blinking.
I checked the belt tension which is within spec. And I also did the A/C diagnostic which gave me code "00" (normal). There is no squeeling coming from the engine. This is a 92 sc300 with 197K. The compressor was changed out at 139k with a remanufactured compressor.
Any Ideas?
Thanks,
Lawrence
Old Jun 15, 2005 | 08:20 AM
jazn671's Avatar
jazn671
sounds like a bad compressor
Old Jun 15, 2005 | 09:02 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
a proper search would have told you bad compressor. specific key words would have been "blinking ac"
Old Jun 20, 2005 | 06:23 AM
ltbong's Avatar
ltbong
Looks like a bad harmonic balancer, rubber is shot, drive belt is slipping.
gs300_94
GS - 1st Gen (1993-1997)
13
Jan 29, 2025 02:35 AM
Jrocxzs
May 27, 2020 08:40 PM
gs300_94
Maintenance
May 31, 2011 10:47 PM
Max Power
Oct 2, 2009 07:39 AM
lbq
Jul 7, 2009 05:18 AM
