View Poll Results: ECT power - driving habbits
ECT is alwasy on
93
24.22%
Only when you are driving aggressively
210
54.69%
Only on the city roads
1.56%
Never
75
19.53%
Voters: 384. You may not vote on this poll
Old Apr 4, 2007 | 11:03 AM
  #76
Daihuy's Avatar
Daihuy
^ Understood almost nothing of that
i figured maybe if i left it on, and drove like granny, nothing would change. I wouldnt be flooring it or anything so i think maybe gas mileage wise, it all depends on the driver and how hard he's driving the car
Old Apr 4, 2007 | 08:23 PM
  #77
drewefx's Avatar
drewefx
i just got my #3 selenoid fixed, prepare for some deep pocketing man, 1700 dollars canadian man, took it to mister transmission. now it rides like a baby. any ideas why this happened anyway?
Old Apr 7, 2007 | 09:48 PM
  #78
Photon440's Avatar
Photon440
What was wrong with the selenoid, and how was the transmission behaving before the repair?
-=Photon=-
Old Apr 7, 2007 | 09:50 PM
  #79
insomniac's Avatar
insomniac
will ECT Power do anything now that i have a performance torque converter in my sc?
Old Apr 10, 2007 | 07:04 AM
  #80
drewefx's Avatar
drewefx
-=Photon=-
The car would **** from 1 to 2 then to 4 then 5 which is over drive
now from 1 to 2 would be instantly, like with in 2 seconds and if you wnated to pass on the highway, there was no such a thing as downshifting cause it was missing the third gear. the engine light was on and the tester said engine selenoid sensor. Now it drives like a baby, i love my car
Old Jun 10, 2007 | 07:38 AM
  #81
mr29rose's Avatar
mr29rose
i just took apart my ect button and noticed the bulbs were burnt inside. and i wanted to make sure how many were n there.
there are 2 small bulns and they are the twist out type. they are smaller than the ons in the a/c unit but a little bigger than the hazard light bulb. i want to know what the part n8umber is for the ect button bulbs? any ideas?
thanks
Old Jun 10, 2007 | 10:34 PM
  #82
Son Gokou's Avatar
Son Gokou
Smile
thanks
This should help u out
Old Jun 11, 2007 | 11:19 AM
  #83
strongsail's Avatar
strongsail
Remember too that the ECU, which controls engine and transmission, uses fuzzy logic to "learn" your driving style. If you drive with a heavy foot, you'll notice less difference with the ECT switch in PWR or NORM. Disconnect the battery for about half an hour and the ECU will reset and will re-learn your habits the next few times you drive the car.
I don't get aggressive in town, but when I want to carve some twisties I flip the switch to PWR. It raises the shift points on upshift and downshift, and YES if you run at higher revs a lot you WILL burn more gas!
Also, in the NORM mode, the ECU slightly closes the throttle when the trans shifts, resulting in a smoother shift, and that also happens on upshifts and downshifts - hence the lag in throttle response when you stab it hard. In the PWR mode, the shifts seem crisper, so I think (don't know for sure) the throttle setting isn't retarded when the trans shifts.
With stock wheels/tires, I get 16-18 in town and 24 mpg on the road. In my previous SC4, when I got Supra TT rims and wider tires, my highway mileage went from 24 to 21. The extra rolling resistance from the larger contact patch cost me 15% in fuel economy.
Old Jun 11, 2007 | 11:24 AM
  #84
mr29rose's Avatar
mr29rose
thanks for the chart
Old Jun 11, 2007 | 01:48 PM
  #85
kyoso23's Avatar
kyoso23
My MPG says I'm averaging 23.2 mpg (city and mostly highway mixed) plus I've got 20's and my spedo is off nearly a full 10th, so figure about 24-25mpg actual right? This is with ECT on all the time, I never really turn it off, but I don't drive with a heavy foot shy of an occasional stab on an on-ramp or something.
Old Sep 6, 2007 | 02:36 PM
  #86
play123boi's Avatar
play123boi
it lets you get better gas mileage.... uhhh yeaaaaa
Old Sep 7, 2007 | 11:27 AM
  #87
p3lon's Avatar
p3lon
OLD. but i drive my car with the ECT off....ON when i need the power
Old Sep 8, 2007 | 09:32 AM
  #88
SC_coupe's Avatar
SC_coupe
Always on. The transmission is way too slushy and lacks response with it off.
Old Sep 9, 2007 | 12:05 AM
  #89
2GTSVETTE's Avatar
2GTSVETTE
off. if i need to down shift i do it my self.... plus most of the time i try to save some gas... am averaging 18.3 mpg.. so anywhere i can save some gas i try.
Old Sep 9, 2007 | 07:12 PM
  #90
t70 supra's Avatar
t70 supra
i dont use mine but my wife has a bad habbit of using it since guys are testing are sc calling it a peice of crap she uses to kill hondas and any other car but dont notice any differences in driving
