? about installing a 5 speed
Old May 24, 2005 | 06:32 PM
littles's Avatar
littles
Default ? about installing a 5 speed
I just got a 97 sc300 and its auto. last weekend i picked up a 5 speed out of a 92. but what am i to do about the auto wiring. When i swap?
Old May 25, 2005 | 01:59 AM
dejacky's Avatar
dejacky
littles, I believe there is an excellent auto-6 speed swap step-by-step article on www.mkiv.com that should be of much help. I'm considering doing the same thing, so if you could chronicle your auto-manual swap experience that would be helpful to me too .
Old May 25, 2005 | 03:55 AM
littles's Avatar
littles
I just want a little more info and i will be puting it in the next two weeks or so.and I will be taking pics.
Old May 25, 2005 | 06:19 AM
mteele's Avatar
mteele
CL Folding 10,000
Did you get the manual driveshaft and rear end as well?
Old May 25, 2005 | 03:28 PM
littles's Avatar
littles
i got just the gear box, drive shaft, pedal cluster , master cylenderand fly wheel.
Old May 26, 2005 | 07:51 PM
JspecSC3's Avatar
JspecSC3
You can use the stock rear with your 5speed drive shafts. The only difference with those rears are the ratios. The auto diff has a 3.7 and the 5speed has 3.2. Oh so I hear. The swap doesnt seem so hard to do.
Also, do you have the whole 5speed transmission or just gearbox (without the bellhousing)? Im not sure if just using the gearbox will do it but if it can go for it. As for the flywheel, I hear you can use the same one off the stock auto tranny. You will need the 5speed driveshafts. 5speed diff. is optional. You will need the master and slave cylinders. And last but not least the 5speed ECU. You can use your AUTO one but its not the same because you'll be getting weird timing so its just best to go with the 5speed's ECU.
Old May 26, 2005 | 08:58 PM
littles's Avatar
littles
thanks , i was worried over the rear end ,and I have the hole 5 speed I just call it gear box for some reason. but thanks again.
Old May 26, 2005 | 09:21 PM
Bean's Avatar
Bean
CL Folding 1,000,000
umm...
stock gears for auto and manual are the same I'm pretty sure; and they are a 4.08
he's talking about the SC300; not a TTsupra
Old May 27, 2005 | 01:53 AM
JspecSC3's Avatar
JspecSC3
Originally Posted by Bean
umm...
ahhh yes thats what it was! Thanks for correcting me.
Old May 27, 2005 | 03:50 PM
littles's Avatar
littles
Smile
well i guess I'm ready, thanks guy
Old May 27, 2005 | 06:01 PM
Bean's Avatar
Bean
np
Cetura
IS - 1st Gen (2001-2005)
Jan 5, 2017 06:01 PM
MichaelYup
Sep 10, 2011 10:46 AM
bzebern
Jun 23, 2008 06:35 PM
SC_DRIFTER
Apr 23, 2007 10:12 AM
driftinfoo
Jul 31, 2005 10:38 AM
