who's running nitrous?
Originally Posted by Dx3
not only is that NOT a discussion
it also doesn't answer my questions nor does it show anyone else's setup
Originally Posted by Goldark
lol
Jonny
Used to have a 75 dry shot in my auto 1993 SC300. Everything stock, even exhaust. I ran it once without mufflers or resonators, but the big restrictor is the cat, I believe. I had no problems with the engine or tranny. I was constanly putting it in and taking it out for warranty services, but nothing out of the ordinary service was done. Used it for 2 years regular
use. Got a bit expensive ($35 to fill a 35lbs bottle which is good for 10 passes in the 1/4 or numerous bursts on the highway... mind you this was back in 1995-97. I have no idea what prices are nowadays).
It was always a joy looking at the face of the guy in the next lane as I purged the system!
use. Got a bit expensive ($35 to fill a 35lbs bottle which is good for 10 passes in the 1/4 or numerous bursts on the highway... mind you this was back in 1995-97. I have no idea what prices are nowadays).It was always a joy looking at the face of the guy in the next lane as I purged the system!
I think you mean for a 10lb bottle. Its about $50 US to fill the bottle these days but depends where you go.
There are very few running nitrous here if any. Don't expect to see any pics of setups here
tmengineering.com is running a 300 shot on stock block. The motor can handle a 100 shot without a doubt. Run colder plugs and use the best octane you can get.
I plan on doing 125+ shot on my sc400 .
tmengineering.com is running a 300 shot on stock block. The motor can handle a 100 shot without a doubt. Run colder plugs and use the best octane you can get.I plan on doing 125+ shot on my sc400 .
Firstly it is a discussion, people are talking about different shots and the necessary equipment to run it.I didn't say this was an answer to your question, nor did I ***** at u for not searching, I simply pointed you in the direction of a recent thread on the topic. So, if you are going to be a ***** when I try and point you in the right direction I will cease to try and assist you in your questions.
Jonny
Jonny
It's not a discussion - it's bashing someone who wants to run 200 shot - and again - it doesn't answer my questions in this thread.
Learn to comprehend what you read.
I can comprehend what I read
Jonny
