Post your 1jz swap issues
Old Sep 27, 2005 | 09:44 AM
  #106
SoarerJzz3's Avatar
SoarerJzz3
Originally Posted by codetoad
Ok, well I should just go ahead and purchase one then. Whats the reason as to why the tach does not work though?
Also, If I were to just purchase a 5speed 1JZ ecu, would everything work properly? Thanks for your help bud
I would also like to know the answer to this question.
Old Sep 27, 2005 | 02:34 PM
  #107
2.5tsoarer's Avatar
2.5tsoarer
I think the reason the tach doesnt work when you do the 1jz swap is diff signal differences on the engines or the soarer cluster uses diff voltage
Old Sep 27, 2005 | 02:44 PM
  #108
Kaiser's Avatar
Kaiser
Distributor to Coil is my guess why it doesn't work. Or analog dash to digital one or the other. I really didn't care. I have a 5sp with a 1JZ running an auto ECU. No check engine lights.
Old Sep 27, 2005 | 06:36 PM
  #109
codetoad's Avatar
codetoad
So if I used a manual 1JZ computer, will I still have gauge problems? Could someone who is running one in their sc please leave feedback on this.
Old Sep 27, 2005 | 10:14 PM
  #110
Bean's Avatar
Bean
CL Folding 1,000,000
IIRC the 2jz-gte and 1jz-gte tachs pull their signal from the cam position sensor or maybe its the lead coil. There's only one coil on the GE motor so the GE tachs look for a different signal.
The tach adapter basically takes this signal and converts to a signal the GE gauge cluster can read.
Old Sep 27, 2005 | 10:15 PM
  #111
Bean's Avatar
Bean
YES. The ECU you use has no bearing on having or not having gauge problems, only your startup.
Old Oct 6, 2005 | 04:08 PM
  #112
Aristo300's Avatar
Aristo300
After reading through this whole thread, obviously the tach problem has been sorted out, and we know the fix, but what about the water temp? Can anyone expand on this....
Old Oct 6, 2005 | 04:16 PM
  #113
blksc300mt's Avatar
blksc300mt
i have a 330 ohm resistor wired into my harness on the orange plug...i think its pin 9...id have to check my diagram to be sure but i think its the yellow with green wire. it keeps the needle a little too low...i'd say about 3/8 of the gauge and it should be 1/2...i think 300 ohm is the one to use...just havent had a chance to get one yet...my local radio shack was out of those.
Old Oct 6, 2005 | 06:22 PM
  #114
plex's Avatar
plex
1UZFE/2JZGTE
What's the hardest part of the 1jz swap my mechanic has done some swaps cressida's etc he said he can do mine just never did 1jz into sc before.
Old Oct 9, 2005 | 04:13 PM
  #115
VJ RC51's Avatar
VJ RC51
hardest part of my swap so far is me, being 6'2ft tall, trying to bend and contourt myself to install the throttle cable, ill be feelin this for a day or 2
Old Oct 9, 2005 | 04:28 PM
  #116
blksc300mt's Avatar
blksc300mt
having to lay upside down to do anything under the dashboard is a pain in the a$$...but i had the throttle cable changed out for the new one in like 5 minutes. ok maybe 10. it'd be nice if the new cable was a little longer tho...it barely reaches the bracket.
Old Oct 9, 2005 | 04:46 PM
  #117
VJ RC51's Avatar
VJ RC51
yeah i was just about to post on that... i pulled on it and hooked it up, but the throttle semed to not work right, maybe bad wire placement... i dont like how much tension u gotta put on that thing, i either might find a way to get another 1/4in out of it, or air freight a soarer one from austraulia and deal with the lenght...
i can either mount the bracket from out in the engine bay or take off that big rubber thing and keep it inside, i think that will give me the lenght i need
Old Oct 9, 2005 | 05:59 PM
  #118
VJ RC51's Avatar
VJ RC51
part # i was sold for the cable is 78180-1B090...
its 1/2in too short. Is it the correct part # or does someone have something different to use
Old Oct 9, 2005 | 07:03 PM
  #119
blksc300mt's Avatar
blksc300mt
i think thats the only one they make for a tt supra....i wonder if one from a different toyota car would work?... my cruise control cable obviously dosent reach either, and i dont really have a way to get one from a soarer...what did you guys do for that?
Old Oct 10, 2005 | 01:14 AM
  #120
got_trd's Avatar
got_trd
use a supra cruise control cable.....
