trac acumulator bleeding (problem)
Maybe some one can help. I have problem with trac bleeding in my SC400. In service manual it is write that traction system can be bleeded too.
Service manual says:
1) ABS bleeding procedure is the same procedure used in
bleeding conventional brake system. On models without TRAC, if master
cylinder is rebuilt or reservoir is empty, bleed master cylinder
first. On models with TRAC, bleed TRAC system first. To bleed TRAC
system, go to step 3).
3) Connect vinyl hose to bleeder plug of accumulator. Loosen
accumulator bleeder plug. Start engine. Operate TRAC pump motor until
all air bubbles have been bled. Tighten bleeder plug to 74 INCH lbs.
(8.3 N.m). With engine running, add brake fluid. Turn engine off.
4) Connect vinyl tube to bleeder plug of TRAC actuator.
Loosen bleeder plug. Start engine. Operate TRAC pump motor until all
air bubbles have been bled. Tighten bleeder plug to 74 INCH lbs. (8.3
N.m). With engine running, add brake fluid. Turn engine off. Clear any
code(s) stored. See CLEARING CODES under DIAGNOSIS & TESTING.
******end service manual*************
And there is problem. HOW OPERATE TRAC PUMP MOTOR ???? When engine is simple running there is no any pressure air or fluid escaping from acumulator. Any... it looks empty...
Second plug on TRAC acuator work fine(when engine working fluid is escaping with open bleeder plug.
Please help.
2. Start engine and Trac pump will automatically start pumping to build pressure, but since bleeder is open it never gets to proper pressure so it'll pump continuously.
3. Monitor brake fluid reservior carefully to make sure it does not get drained, the fluid will pump out pretty quickly.
4. Close bleeder when all air is out of system and fill reservoir to proper level.
Pretty easy actully, just need to watch brake reservior level.
Good luck,
djl
Good luck,
djl
There is a trick to it and the funny thing was that the trac actuator on the right side had tons of air in it but the accumulator had none. The post above describes how the valve on the actuator had to be open before cranking to get it to bleed. The accumulator is bled by lifting the rear tires off the ground and giving gas in drive to initiate (or Lexus shops may use an SST). Good Luck.
There is a trick to it and the funny thing was that the trac actuator on the right side had tons of air in it.[/QUOTE]
Thanks for posting this, where would this bleeder on the actuator located at on the LS400 ?
thanks.
please help thx
....but the procedure written above seems right from what i have seen before.
