What to do before S-AFC install - other mods?
Old Feb 18, 2005 | 12:10 PM
Dx3's Avatar
Dx3
Default What to do before S-AFC install - other mods?
Guys,
I am bringing my car in to get it dyno tuned with my Apexi S-AFC.
I am wanting to install and intake and a grounding kit before I do it though as I want my settings on the S-AFC to be accurate.
Anything else I should consider doing that may make a change before I get it tuned?
I have just done my full exhaust, so grounding kit and intake are all I can think of that are not expensive.
Lemme know what u think,
Peace,
Jonny
Old Feb 18, 2005 | 12:26 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
looks like an engine related question to me
Old Feb 18, 2005 | 12:56 PM
got_trd's Avatar
got_trd
clean/change/check gap on spark plugs, clean the injectors, oil change and you should be str8
Old Feb 18, 2005 | 05:34 PM
CP_Ree's Avatar
CP_Ree
Grounding kits are a waste of money. Save your money. Just my .02. Just make sure it runs good, that's all you need to do. Most likely all there will be to do on the AFC is lean it out a tad to make that extra 5 whp that's in it. When I was dynoing mine for fun, it was quite rich, but didn't seem like there'd be a significant amount of fuel I could take out that would make a reasonable amount of power. I see it in all the cars that come in to do basic n/a afc tunes.
Old Feb 18, 2005 | 06:15 PM
Dx3's Avatar
Dx3
Well I need to replace my negative battery cable anyway so I was jsut going to go with the whole kit.
So you think the S-AFC only makes 5 whp?? That sucks - I was hoping for a little more than that
Peace,
Jonny
Old Feb 18, 2005 | 07:14 PM
got_trd's Avatar
got_trd
if ur n/a it wont do much....
Old Feb 18, 2005 | 07:24 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
Something I'd have a look at as well is inspecting/replacing the O2 sensor. I think mines faulty lol so I need that replaced before fitting in an S-AFC, check air filter too (unless you've already done that).
Oh yeah, and we wanna see pics of your new pride and joy
Jose
Old Feb 18, 2005 | 07:38 PM
VSsc400's Avatar
VSsc400
you guys should really do a search.
on a 92 SC400 S-AFC tuned to very safe levels will yield 10rwhp in 90% of the fuel curve and 15rwhp on some spots.
don't guess when the answer is out there.
Old Feb 19, 2005 | 10:57 AM
blacksc400's Avatar
blacksc400
Car Chat Moderator
I have SAFC installed on so many cars, but I fried my first 92 SC400's main ECU and Fuel pump ECU within 1 month after I put it in... and trust me, I know how to tune SAFC because I have it in 3 other cars before... and I only tuned my last SC400 fuel CORR with in +- 3%!!!! Now I have another 95 SC, and guess what, I am NOT putting it in!!
Old Feb 19, 2005 | 01:06 PM
VSsc400's Avatar
VSsc400
I'm sorry about the frying main ECU and fuel pump ECU within 1 month after you put it in.
I think that's a very rare case.
I've had mine on my 92 SC400 since 10-11-03. Since then I've put in something around 40k miles on my car.
So what made you correct your fuel within + - 3%? how did you know if you needed to add or take out fuel? Gauges? wideband? dyno?
my settings are
Hi-Throttle settings
1000RPM = -3%
2000RPM = -4%
2500RPM = -5%
3000RPM = -6%
4000RPM = -8%
5000RPM = -9%
6000RPM = -10%
6500RPM = -9%
Lo throttle settings
1000RPM = -2%
2000RPM = -3%
2500RPM = -4%
3000RPM = -5%
4000RPM = -7%
5000RPM = -8%
6000RPM = -9%
6500RPM = -8%
I'm not saying that you don't know what you are doing but i think you may have shorted something out for the main ECU and fuel ECU to both get shorted out. Or the car had electrical problems to start with.
https://www.clublexus.com/forums/sho...ighlight=s-afc
needless to say I've had no problems with my main or fuel ECU or anything else in the car.
Old Feb 20, 2005 | 07:05 PM
NAZTY97's Avatar
NAZTY97
I'd have to agree with VSsc400, there is no way to know how much hp an SAFC is going to do any car until you put it on and properly tune it to that vehicle. 2 of the same vehicles of the same year can vary in Hp by up to 10 - 15hp,... so right there begins the first of many possible variants.
As stated, in a search you find I gained like 20 hp and 24 ft lbs of torque in certain rpm's and 2 or 3 hp gains in other areas,.. so don't get caught up in peak power gain,.... be more concerned with driveable / usable hp, which is not at redline.
Old Feb 22, 2005 | 09:48 AM
blacksc400's Avatar
blacksc400
Car Chat Moderator
Well, I guess probably the car has problem to begin with since I have put the SAFC in couple other cars I had before and had no problem. But anyway, this is my 3rd SC and I don;t know how long I will keep it, I don;t feel like risking it to put in the SAFC, should put SAFC up for sale soon, (Hint Hint)... I don;t know how much I should ask for the SAFC, anyone wants it can give me a PM..
Old Feb 22, 2005 | 12:31 PM
VSsc400's Avatar
VSsc400
I got my S-AFC in mint condition, in original box with original manuals with the stand for $200 or $220 shipped (from MA to CT) about 2 years ago.
wowitztai
Jul 23, 2008 01:01 PM
ShaneC
Performance
18
Aug 30, 2006 01:31 AM
Dx3
Mar 27, 2005 05:05 PM
BFDRACER1
Performance
Jan 3, 2005 09:54 AM
