Check Engine light SC300
Old Jan 21, 2005 | 07:10 AM
Salil022's Avatar
Salil022
Default Check Engine light SC300
this is the second time check engine light came on, after i reset it by taking the battery terminal off and put it back, light won't come on for about 1,000 or so miles, its weird any help would be appreciated its a 95SC300 5spd
Old Jan 21, 2005 | 09:14 AM
SPORTcoupe's Avatar
SPORTcoupe
Originally Posted by vredniykot
edit: Intellexual.com is down until further notice. It is no longer a Lexus web site so please move on.
Were you looking for http://intellexual.net/ ?
~Alan
Old Jan 21, 2005 | 09:51 PM
Ikrshinji's Avatar
Ikrshinji
I had a similiar problem with mines. Turned out to be the gas cap. After replacing it, I had no more problems. Hope it's nothing big
Old Jan 22, 2005 | 12:57 AM
rscott's Avatar
rscott
holy crap i have never seen you post.
good to see its a useful one
Old Jan 22, 2005 | 01:00 AM
rscott's Avatar
rscott
back to the topic at hand. Its really hard to diagnose anything without first pulling the codes. After you do that, we'll be able to tell you what it is.
When my egr started on the fritz (still is) i started pulling codes every couple hundred miles.
but again its hard to say anything until codes are pulled
Old Jan 22, 2005 | 08:45 AM
Dx3's Avatar
Dx3
Tell us your codes and we will tell u ur problems!!
Peace,
Jonny
Old Jan 22, 2005 | 11:12 AM
Salil022's Avatar
Salil022
thanks everyone how do i pull the codes, i know its a dumb question, i mean do i jump wires on the diagnostic terminal under the dash? if yes can anyone tell me in which port exactly i have to jump wires? any help would be appreciated
Old Jan 22, 2005 | 11:58 AM
rscott's Avatar
rscott
in the engine bay youll find the diagnostics port (not sure where since its an sc4), but jumper ports T1 and TE1.
I believe thats it, they will be diagonally right next to each other. Someone else please confirm this.
Old Jan 22, 2005 | 05:21 PM
Salil022's Avatar
Salil022
sorry i dont have a manual if anyone can post pics or tutorial that would be helpful
thanks
Old Jan 22, 2005 | 06:56 PM
Salil022's Avatar
Salil022
thanks alot man i am going to pull the codes tomorrow during the day and post the results
appreciate your help people
Old Jan 23, 2005 | 01:15 PM
Salil022's Avatar
Salil022
i just jumped the wires for the check engine light, light flashed twice and then big pause and then one flash, so does that mean code 21?
let me know thanks
Old Jan 23, 2005 | 01:40 PM
rscott's Avatar
rscott
ouch...
Code 21:
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
good news is its probably an easy fix...bad news is the o2 sensors can be a little pricey
Old Jan 23, 2005 | 02:25 PM
Salil022's Avatar
Salil022
should i just replace the main sensor on the exhaust manifold? and if yes where can i buy one at fair price
thanks
Old Jan 23, 2005 | 03:01 PM
rscott's Avatar
rscott
you know, i was just thinking - if it's a O2 sensor failing why does it go away after clearing and comes back later?
could it be possible that the cat. converter is going bad?
i'm not too familiar with the codes, is this code means that there is actual physical problem with the sensor itself?
means the ecu isnt getting signal from the o2 sensor. It may be all clogged up and burnt out that its just not producing the same voltage anymore.
kkochan
Dec 10, 2023 05:27 PM
kchat99
May 23, 2019 06:26 AM
ALLWiTE2JZ
Dec 9, 2009 04:04 PM
sc400 2nv
Apr 9, 2008 05:50 AM
KidPandJ
Feb 28, 2005 02:39 PM
