electric fans on for 3 seconds???
Old Dec 7, 2004 | 09:48 PM
prjctSC300's Avatar
prjctSC300
Default electric fans on for 3 seconds???
i installed my fal 210's and when the fans kick on, they only stay on for about 2-3 seconds and shut off. is this normal for the electric fan conversion??
Old Dec 9, 2004 | 08:36 AM
prjctSC300's Avatar
prjctSC300
calling all people with electric fan set-up...so is it normal??
Old Dec 9, 2004 | 01:25 PM
siaxazn's Avatar
siaxazn
did u put in the supplied thermostat relay? It shouldnt turn off unless the car is under a certain temperature. I beleive its supposed to kick in at around 270 degress or something and stay on till the temperature drops below a certain temperature. I have mine wired to be on all the time. if the fans are not on when the car is past 270 your car will surely overheat.
I overheated a few times when my connect fell loose and my fans turned off but now i made sure to secure my connects and solder everything.
Old Dec 9, 2004 | 01:56 PM
prjctSC300's Avatar
prjctSC300
i didint use the supplied black box, instead my friend gave me a thermo fan switch off a nissan 240sx with the tee adaptor, and i spliced it in between the lower radiator hose..the car doesnt overheat and i have driven it in traffic for an hour without it overheating. any other ideas?
Old Dec 9, 2004 | 07:30 PM
wmulli's Avatar
wmulli
If it's not overheating, what's the problem? It sounds like the thermostat switch is turning them on when needed. It's probably safe to assume it's turning them off when not needed.
Does it cycle frequently, like a few seconds on, a few seconds off? If so, you might want to adjust your turnon temprature to be a bit higher. Otherwise, if it only takes 3 seconds, so be it!
My 210's run for 10-15 seconds at a time, but come on infrequently and my gauge never goes above the halfway mark (not that that means anything for these cars )
PS - If you're having the dreaded vibration problem with them, FAL will send you new, balanced blades for FREE!
Old Dec 9, 2004 | 08:30 PM
prjctSC300's Avatar
prjctSC300
i thought that the vibration was normal, but free balanced, sure why not!!! do you have to send them your old ones first??
Old Dec 9, 2004 | 08:42 PM
wmulli's Avatar
wmulli
Contact Bob Reader at Flex-A-Lite - bob@flex-a-lite.com. They'll want you to send in some kind of proof of purchase and then they just send the blades. Sweet!!
Old Dec 9, 2004 | 08:59 PM
prjctSC300's Avatar
prjctSC300
i bought mines off my friend, so i dont have a proof of purchase. am i still eligable??
Old Dec 9, 2004 | 09:16 PM
wmulli's Avatar
wmulli
I couldn't say. Contact Bob and explain your situation. You've got nothing to lose!
You could ask him about the 3 second thing as well!
justinciub
RX - 1st Gen (1999-2003)
Mar 17, 2025 06:43 AM
dusouth
Jan 2, 2018 07:41 PM
Dvinhie
Feb 17, 2014 01:02 AM
Murphydurf
GS - 1st Gen (1993-1997)
Aug 15, 2013 05:52 PM
matt7184
Jan 22, 2002 06:53 PM
