Question
Old Jun 23, 2004 | 07:24 PM
BCSC300's Avatar
BCSC300
Angry Question !!!!UPDATE!!!!
What's up guys, Here is my situation, the other day I was sitting at the lights when my 92' SC300 w/
150,000 miles started to feel as if it was misfiring. Once I pulled into the driveway I pulled two plugs and
noticed that they had some oil on them. So what I did was I went to the dealership bought some plugs,
wires, rotor, cap, and PCV valve. Finally, once I completed the tune-up I get in to start her up and what
happens is the car jumps up to 2,000 RPMs and then completely dies out! I don't know what I did wrong I
checked all the vacuum lines, they were in order. Wondering if the TSP unit needs to be replaced, or
something needs to be adjusted? Any suggestions would be very appreciated.
Thank You,
Brian Carvalho
Old Jun 23, 2004 | 08:07 PM
SupraCoup3's Avatar
SupraCoup3
hey brian -- where are you located? I'm in Lexington... nice to see another SC owner from MA
I don't think it's your TPS sensor, are you throwing any check engine lights? It could be fuel related... have you been blowing any smoke when you start the car? It's strange that you would get a fast idle, then have the car fall on its face. Can you provide any more background info?
Once again, I don't think it's your TPS sensor, but if you want to mess around with it, here's how:
you can adjust how fast your idle is by losening two screws and adjusting the sensor clockwise and counter clockwise. Be sure to screw it back down good when you're done.
JT
Old Jun 23, 2004 | 09:00 PM
BCSC300's Avatar
BCSC300
What's up Brother, I'm located in Fall River
As far as any codes none have come up, Its funny you mention the smoke because there is a white puff
every once and while at startup only. The reason I assumed it was the TPS sensor was because I
removed it during the tune-up (was I suppose to?) I just hope its nothing internal that busted on me. Oil
on the plugs isn't really a good sign I’m going to try to fool around with the adjuster on the sensor
tomorrow morning. Thanks again SupraCoup3 I’ll let you know how I make out on the adjustment, if you
or anybody else can think of any more suggestions please post them.
Thank You,
Brian Carvalho
Old Jun 24, 2004 | 07:13 AM
SupraCoup3's Avatar
SupraCoup3
Are you sure the oil on the plugs wasn't from mechanics spilling oil everytime they change it? (it pools in the wells)
Which plugs had more oil? Have you thought about a compression test?
A white puff is coolant or water... how's your coolant levels?
Also, make sure you reconnected all your vacume lines correctly.
JT
Old Jun 24, 2004 | 10:53 AM
BCSC300's Avatar
BCSC300
I do my own oil changes, recently i did make a little mess with the 5quart from WALMART, but i don't know
if it would float all the way make to Plug #6. Plugs #3 & #6 had the most oil, but all plugs did have some
oil on it. I adjusted the TPS sensor to the point where she stays running but quickly idles from normal to
2,000RPMs, I tried to tap the gas pedal to see if it would straiten out, but it jumps to 5,000RPMs and
slowly climbs back to 4,000RPMs and just sitsthere. I do get a white puff every once and a while. All
coolant levels seem to be fine as well as vacuum lines in order. I have never had a compression test
done. It seems like the TB should be adjusted, is there anyway of doing that?
Thank you,
Brian Carvalho
Old Jun 24, 2004 | 10:55 AM
VSsc400's Avatar
VSsc400
check the PCV valve.......
Old Jun 24, 2004 | 11:36 AM
BCSC300's Avatar
BCSC300
I replaced the PCV valve, i did notice that it did not fit as tight as the old one.
Old Jun 29, 2004 | 10:52 PM
BCSC300's Avatar
BCSC300
Default Question !!!!UPDATE!!!!
What's up guys, my mechanic replaced my valve cover gasket and adjusted my TPS just right. So all is well
now. Has anyone ever experienced this problem?
Anyhow I want to personally thank SupraCoup3 and VSsc400 for their efforts on my car troubles.
Thanks Again,
Brian Carvalho
Old Jun 30, 2004 | 11:24 AM
VSsc400's Avatar
VSsc400
Default Re: Question !!!!UPDATE!!!!
Thanks Again,
Brian Carvalho
you are welcome. Sorry i was not able to give you the right answer. I've replaced my valve cover gasket during my 90k service along with timing belt and such. I never had to adjust my TPS.
glad to see that you got that worked out right. Have fun with the car now!
Old Jun 30, 2004 | 04:01 PM
indypwr's Avatar
indypwr
Post
just take out all the plugs wires and plugs and let the area
where spark plugs screw in dry up! that happened to me while i was driving in the rain,
the water somehow got inside the plug holes due to maybe bad or faulty rubber seals
in the middle of the hood area towards the windshield. my car started misfiring and it felt like
only 3-4 cylinders were firing up! so all i did was took out all the plugs/plug wires and let them dry
out. also, i used dry rag and inserted into the hole where the plugs screw in and made sure
around that ares is also dry! after that, i re-sealed the rubber piece arond the hood
and never happened again!
good luck!!
Old Jun 30, 2004 | 09:08 PM
BCSC300's Avatar
BCSC300
Will do VSsc00; definitely overdue!!!
QUOTE]Originally posted by indypwr
good luck!!
[/QUOTE]
According to my mechanic, valve cover gaskets is common occurrence in mostly all in-line block motors.
An Example SC300s, late 80’s BMW 325, 1990’s Jeeps, etc. My mechanic also stated that motors like the
SC300s make perfect valleys for water, spilled oil from oil changes. Thanks for the advice indypwr, after
reading your post that is definitely something to consider and a cheap fix.
Thanks Again,
Brian Carvalho
Sep 18, 2017 07:08 PM
blazin3gen
Mar 23, 2006 10:23 PM
Salil022
Feb 19, 2006 07:31 PM
Yg_green1
GS - 1st Gen (1993-1997)
Sep 22, 2005 02:53 AM
