97+ Tails do NOT like ovens
Old May 20, 2004 | 03:13 PM
CleanSC's Avatar
CleanSC
Default 97+ Tails do NOT like ovens
In an attempt to custom mod a 97+ tail, I melted a brand new light in my oven. Of the 10+ lights I have put in the oven, this is the first to melt on me.
I was quite upset, it was a brand new light purchased in the GB. Steve has a new one to replace it on the way already. He's been great.
For the record:
Oven preheated to 225 degrees. Light was placed in the oven on a cookie sheet for 9 minutes. That's all it took. After I got it out, the glue was like syrup. It dripped into the inside of the light and it came apart like the glue was not there. Pulled apart very easy. Too bad the light was destroyed. Anywhere the black glue cools and hardens, it's there - permanently. It's tenacious stuff.
This new black glue requires a higher temp to get it loose. The older lights use a gray glue which softens at a lower temp and I've never had a problem.
So for you wanting to customize these, watch your temperatures carefully. These are not as easy as the lights with the grey glue. The outer pink lense also melts rather easily.
Old May 20, 2004 | 03:48 PM
Ice350's Avatar
Ice350
Default mod?
I'm lost. What mod were you attempting that require cooking the light? Really...I don't know. I'm sure I'm not the only one. Please explain.
Thanks.
Old May 20, 2004 | 03:56 PM
indypwr's Avatar
indypwr
Post
i think you left the light too long................dang...........9 mins?
when i worked on my headlights on my gs, i only let it sit there for 3mins max!!!
even wrapped with damp towel.
sorry to hear that, bro....next time, just let it cook for 3 mins after the oven has warmed up to 300deg.
hope that helps.
Old May 20, 2004 | 03:58 PM
makenzie70's Avatar
makenzie70
He's removing some of the lense material inside....it's nothing special but it does look nifty.
I've learned that when doing things like this it's better to leave the lights in the oven at only 2 minute intervals. With my RX7 and Supra lights it took about 20 minutes a piece with them in and out...which means it's a lot more tedious but you don't have to worry about mishaps like this.
Old May 20, 2004 | 04:39 PM
MrJohnTan's Avatar
MrJohnTan
Default Re: mod?
He was hungry
Old May 20, 2004 | 04:52 PM
Ice350's Avatar
Ice350
Default mod???
[QUOTE]Originally posted by makenzie70
[B]He's removing some of the lense material inside....it's nothing special but it does look nifty.
Removing some of the lens material makes it look better? Hmmm...I'll have to see it to believe it. Anyone who has done this have pics? Please post.
Old May 20, 2004 | 05:09 PM
CleanSC's Avatar
CleanSC
Guys:
The SC headlights will take 10 minutes in there no prob. I just did 2 right now.
But to be safe with an unfamiliar unit, I did put the tail in for 8 minutes, and it wasn't enough. The glue was rock solid. So I let it cool, and put it in for 9 more.
Obviously it was too much.
The mod I was after was unclear. I usually let the mods come to me after it's open and I try different things and see how they look. Mainly, it was to make the lens all red and eliminate the amber which kills the light IMO. Then once it was open, look into LEDs, etc...
Here's a pic of the fried light with the amber eliminated. This is the flavor I am after. I'm not a fan of the amber at all.
Old May 21, 2004 | 08:38 PM
Aznteazer's Avatar
Aznteazer
damn if it melts that easy, i'd rather use a heatgun.
Old May 22, 2004 | 05:59 AM
Ice350's Avatar
Ice350
Default cooked lights?
Originally posted by CleanSC
Guys:
I don't see much difference. Can I see a before and after pic?
Old May 22, 2004 | 06:56 AM
Xanadu350's Avatar
Xanadu350
Yeah, can we see a before & after, it's hard to tell without seeing the before & after side by side. Thanks
Old May 22, 2004 | 07:45 AM
CleanSC's Avatar
CleanSC
Default Before and after
As requested.
Top is all red 97 tail (try to ingore and look past the melted cover lens)
Bottom is stock 97 tail with the amber portion. IMO, the amber kills it. the upper light is much more uniform, and at flows better. That amber square on the stocker makes the light clash with itself.
Pics on the car would make more of a difference. The lights side by side don't portray the effect too much. But you get the idea of what was being modded.
Old May 22, 2004 | 08:47 AM
Ice350's Avatar
Ice350
Default home cooking
Now I see, you don't like the yellowish color on the rear lights. Well...to each his own. I happen to like the way the stock light looks. Maybe one day I won't like it and will know what to do...either cook it up or buy one without the amber. Good thing I'm an excellent cook. My 95 has only faint yellow, I wish it stood out more.
Old May 22, 2004 | 08:51 AM
CleanSC's Avatar
CleanSC
LOL Reggie, you got yourself a deal.
At the next meet I'm bringin a doggie bag.
Old May 22, 2004 | 09:39 AM
Xanadu350's Avatar
Xanadu350
Thanks for pics, I like it either way.
maynanator
May 16, 2015 09:51 PM
wagomaniac
Jan 23, 2010 10:14 PM
Blizzy
Apr 20, 2007 05:54 AM
lexsc492
Feb 5, 2006 05:39 AM
