removing steering wheel
Old May 7, 2004 | 01:21 AM
qmtran's Avatar
qmtran
Default removing steering wheel
sorry, but i cant find this topic in the search. has anyone got the instructions on removing the steering wheel?? i just got the momo tuner wheel w/ the supra hub and need to install it before the next car show. thanks guys!
Old May 7, 2004 | 09:02 AM
ACleanSC4's Avatar
ACleanSC4
there are 2 plastic covers on each side of the steering wheel that pop off...
then there are 2 torx screws on each side to loosen...
then the airbag should come out and unplug it from the steering wheel
lastly, there is a bolt in the center of the wheel...
I did this awhile back, I think that is the right procedure....you might want to unplug the battery before trying any of this...
Old May 7, 2004 | 11:33 AM
indypwr's Avatar
indypwr
Post
what other types of steering wheel fit our cars anyways?
Old May 7, 2004 | 11:56 AM
SC400Dude's Avatar
SC400Dude
My '95 Supra Turbo supra steering wheel should be arriving mid-may - it should bolt on problems free. MrJohnTan did this and it looks cool IMO. Plus, I got it for $150 shipped with the airbag
Any aftermarket wheel with a supra hub should fit as well. I've also heard that late-model Lexus 3-spoke steering wheels fit too....
Old May 7, 2004 | 01:07 PM
indypwr's Avatar
indypwr
Post
i see........cool.
tks for the infos
Old May 7, 2004 | 05:55 PM
MrJohnTan's Avatar
MrJohnTan
Dont forget to drive down the street a little bit to make sure the wheel is straight before you put everything back together. I didnt realize I put the wheel back on off center just a hair until I put everything back together.
Old May 8, 2004 | 01:31 PM
Nobb's Avatar
Nobb
Hey Slick- It may be a good idea to disconnect your battery first.
Old May 8, 2004 | 02:38 PM
qmtran's Avatar
qmtran
i havent taken the time to take it off yet, but are the wires for the horn a certain color?
Old May 8, 2004 | 08:20 PM
MrJohnTan's Avatar
MrJohnTan
Hey Slick- That was already mentioned
If i remember correctly, the horn and cruise control are connected via a single harness. I forgot what the color was. The airbag is the bright yellow harness.... cant miss it.
Old May 23, 2004 | 06:53 PM
qmtran's Avatar
qmtran
ok heres my problem. the wheel is removed, new one on. the harness where the power steering wheel on the colum, i trimmed to make the hub fit. but the thing is the wheel feels tight and every time i turn the wheel it feels as if i have no power steering. also, the steering colum moves as the wheel is turning. whats wrong?
Old May 23, 2004 | 10:36 PM
SC400Dude's Avatar
SC400Dude
Hey Tran,
PM a member named "AnthraciteSC" about your steering wheel woes. He has the Momo steering wheel/Supra hub combo....maybe he can give you a few pointers....hope this helps.....
Old May 23, 2004 | 10:51 PM
qmtran's Avatar
qmtran
Default help w/ momo supra hub
my problem is when i installed the hub to colum, then the steering wheel to that, it feels as if the hub is rubbin or grinding on something. did you have this problem? or do you know what the problem is?? if feels as if i have no powering steering and the steering colum moves when i turn the wheel. please help. thanks for your time
Old May 24, 2004 | 10:15 AM
The Ikon's Avatar
The Ikon
FIRST!!!! Disconnect the battery!!! A discharged AIRBAG can KILL YOU!!!
Secondly, find the airbag fuse!!! Take it out!!!
Thirdly, step on the brake once then release and wait at least 10 MINUTES...
Next, ground yourself, by touching something metal in your car...
Next put on a pair of latex gloves...
Now follow CleanSC instuctions!!! Clean, is that car still TIGHT?!
I hope this helps.
The Ikon
Old May 24, 2004 | 10:24 AM
mikeloc24's Avatar
mikeloc24
Old May 24, 2004 | 10:39 AM
qmtran's Avatar
qmtran
i did that ikon, i guess i forgot to mention that. it feels as if its caught or rubbing on something. its stiff.
