Aftermarket 3.26 diff
Old Aug 23, 2025 | 06:17 PM
CasualT83's Avatar
CasualT83
3rd Gear
Default Aftermarket 3.26 diff
So I have 95 sc400 swapped with a cd009 and a welded 3.26 diff. I want to get a new LSD with the 3.26 ratio. What are y'all using? Any suggestions?
Old Aug 24, 2025 | 01:25 AM
KahnBB6's Avatar
KahnBB6
Hello and welcome to the forums!
If your current 3.26 diff gears have been welded then you'll need to get another 3.26 diff to start with from scratch. Check the SF thread below where all the available donor cars that came with a 3.266:1 ratio are listed. Getting one from a 2002-2005 SC430 is probably the most drop-in option without having to swap the companion flange (which isn't a big deal if you need to). FYI, 2006-2010 SC430's came with 3.769 diffs.
https://www.supraforums.com/threads/...l-info.608545/
As for the LSD... you've got a few options. The best of them all is an OS Giken Super Lock 1.5-Way. There's also the Kaaz Quiet 1.5-Way. TRD 2-Way LSDs are now used only but can be serviced. Kaaz and OS Giken also both make a 2-way versions of their LSDs. For the street it is highly recommended you go with a 1.5-way LSD.
I've had a used 1994 Supra Turbo Automatic Torsen T-1 LSD in my SC300 for 14 years (first with a custom 4.272 ratio and later with a full diff rebuild back to its original 3.769 ratio). It's great for lower power applications below 400-450whp max but at that point an aftermarket LSD is highly recommended as the Torsen T-1 begins to reach its limits of predictable behavior under certain conditions by 500whp+.
Plus used factory Torsen LSDs for these cars have been used only and pricey for many, many years. Whether one is right for you vs an aftermarket LSD (and assuming you can find a 200mm Torsen as they only rarely come up for sale and go very fast when they do) is a matter of personal preference. It has been my plan to upgrade to the OS Giken 1.5-way at some point.
To note: There also exists a JDM 200mm Torsen T-2 LSD that has superior characteristics to the much more common (in the U.S.) T-1. Late 90's JDM Supra MKIVs, late 90's Soarers and late 90's Aristos got this version of the Torsen for the differential type that we use. But they are VERY rare to find.
Old Aug 25, 2025 | 04:11 PM
CasualT83's Avatar
CasualT83
3rd Gear
So I found a 2004 ls430 diff, that should work right?
Old Aug 26, 2025 | 06:01 PM
KahnBB6's Avatar
KahnBB6
I believe it should, yes. Same diff shape and bushing locations as our diffs as I recall. You will need to swap over your SC300/400 companion flange. Follow the SC300/400/MKIV TSRM procedure for that with the correct torque using a dial-gauge torque wrench and with a new OEM crush nut.
Old Sep 21, 2025 | 09:07 AM
CasualT83's Avatar
CasualT83
3rd Gear
Ok I've got the ls430 diff ready to install. Just having trouble find the tourqe specs for the driveshaft, half shafts, main mounts and the 3 hex bolts on the back. Should I be looking for ls430 tourqe specs since that's the diff I'm using?
SCVito
May 6, 2022 06:13 PM
3isivun
Nov 13, 2020 04:59 AM
tuninghaus
Aug 12, 2007 10:10 AM
LasVegasGS
Performance
21
Jul 28, 2005 07:42 PM
laxdude362
Jan 12, 2005 09:38 PM
