Instrument Cluster Lighting Solution
Old Aug 11, 2023 | 07:11 AM
bbyatv's Avatar
bbyatv
Default Instrument Cluster Lighting Solution
So when I originally went to repair the back lighting on my 1995 SC300 instrument cluster, I went with the Tanin LED kit. Since then I have had many of the bulbs Tanin sold me burn out. Also, they are a true white color. I have since discovered an LED bulb that almost matches the original warmer yellow of the original incandescent bulbs perfectly.
The new LED bulbs I am using are from https://www.superbrightleds.com/
The part number for the bulbs is 74-WWHP3, 10-16 VDC, 360 Beam Angle.
Please see my build thread for a good set of instructions on replacing the bulbs.
https://www.clublexus.com/forums/bui...l#post10722254
Hope this is helpful.
Bruce
Attached Thumbnails Instrument Cluster Lighting Solution-sc_led_bulbs.jpg   Instrument Cluster Lighting Solution-sc_led_lights.jpg
Old Aug 11, 2023 | 10:54 AM
RudysSC's Avatar
RudysSC
My needles are starting to go and I need to do this too. I LOVE that these are a little closer to the original hue. I hate the brite white replacements as they don't match anything else in the car unless you go through the center console and do the same. Lookin good out there man - maybe I'll pull mine out and give this a go over the winter time.
Old Aug 14, 2023 | 12:38 AM
KahnBB6's Avatar
KahnBB6
I'm ordering all new OEM bulbs soon for mine. I haven't had much seat time in my SC this year but the LED backlighting bulbs they installed (at my request) aren't always 100% perfect. I think it's just the nature of aftermarket LEDs in those locations perhaps. In 2010 just after getting my car I installed all new OEM backlighting bulbs and they were still 100% perfectly operational when I sent my cluster to Tanin sometime in... 2021 I think? No complaints about the needle upgrade though!
bbyatv, if you'll be doing this be sure to run the specs of those bulbs by the notes in O.L.T.'s thread on the subject as he's our resident expert on 1992-2000 SC instrument clusters:
https://www.clublexus.com/forums/sc-...usters-77.html
Deegee
Aug 10, 2016 02:26 PM
imAC
Nov 18, 2013 04:53 AM
Bankswood
Oct 1, 2012 04:23 PM
evilninja
Dec 17, 2010 11:07 PM
KPC
IS - 1st Gen (2001-2005)
Nov 2, 2008 01:42 PM
