VSS (Speed Sensor), Trans Fluid
Old Jul 3, 2023 | 11:31 AM
ToeNee's Avatar
ToeNee
Question VSS (Speed Sensor), Trans Fluid
Hello, recently I've been getting bad shifts out of first and after 15-30 mins of driving on the highway I me o/d light would start flashing. I've done a lot of research on this, and I think the conclusion that my VSS (Veachel Speed Sensor) is bad (bad shifts, speedometer is shaky, o/d flashes) and my trans fluid is bad (its a darkish maroon colour). Does this make sense? I am thinking about replacing both the VSS and trans fluid at the same time. Any info anyone has on this I'd appreciate.
Thanks
Old Jul 3, 2023 | 08:22 PM
Tallyhoe's Avatar
Tallyhoe
Trans fluid should be replaced, but if you can afford it, request a transmission test kit from Blackstone. The kit is free99, you get charged once you send in the sample and request the test, and they will send you an overall condition of the transmission. It was like $45 a couple of years ago.
Old Jul 13, 2023 | 01:29 PM
Ldepaso's Avatar
Ldepaso
i had same exact issue on my 92 sc400 i replaced the 2(small) transmission shift solenoids and did the fluid replacement, car was shifting smooth like butter and O/D light was gone!
Its $250 for 1 at the dealer you can get it for $100 each from Rockauto.com
OEM / Interchange Numbers: 8542022080
https://www.rockauto.com/en/catalog/...+solenoid,8476
Lexus4321
GX - 1st Gen (2003-2009)
Oct 28, 2021 09:46 AM
Ryan07es
Sep 2, 2020 05:35 AM
Dx3
Sep 5, 2016 07:40 PM
mark98ls40
Dec 20, 2010 09:13 AM
99LS400BLK
Jan 16, 2007 12:32 PM
