Apple maps integration with RZ battery levels
Anything you guys can suggest to make it work again. I am lost here completely. Thanks
1. Contact Lexus App Support and reference the known issue. They should be aware of similar cases.
Ask them to escalate it as a server‑side battery telemetry sync failure.
2. Check for Lexus app updates. Several owners regained EV routing after a backend or app update — not after any local troubleshooting.
3. Wait for Lexus to fix the backend. Not satisfying, but based on all reports, this is the only thing that has worked for others.
4. Temporary workaround: use the app A Better Routeplanner (ABRP).
There was never any support for battery level support in Android auto so I cannot count on that either. Hope the above helps.
Interestingly enough, I did get it to catch one time! It triggered and enabled the feature, but the vehicle's name had the phrase "null" in it! It's as though the software somehow did at least a partial handshake, but failed to get it entirely, because the routing feature, while technically enabled (Vehicles now appeared under my profile in Maps), it didn't actually function properly... it was like a half-baked handshake of some sort (I am not a software guy so I couldn't really tell you).....
Anyway, that's at least a glimmer of hope. It "tried" to connect, but didn't really work. I was optimistic, so I pulled everything again, nuked the CarPlay connection, removed the car from my Bluetooth, forgot my device from the car, etc, etc., and just "started all over" - and now, I can't get it to do anything after tapping the button in the Lexus app to enable it. It just switches me back over to Apple Maps and does nothing.
Sad...
Hopefully this is fixed, eventually.... it would be nice. But, at the end of the day, I am very rarely going to take any long trips that would warrant it, and I can very easily plan my own route. So, while I don't need it, it would be pretty nice to have!
I basically just kept trying it every once in a while. I might have tried maybe once or twice a day, or every couple days. I would open the app and hit the button to enable the feature.
suddenly it just worked, just a couple days ago! Whatever handshake it needed, it did it.
so, I suggest to others just keep trying every once in a while and maybe it’ll work like it did for me!
I will say that it seems that you must actually get in the car and connect to CarPlay before the battery percentage changes in Apple Maps. It seems like it’ll go hours and hours without updating but I think actually getting in the vehicle seems to push the update.
if you want something that works well and connects with the car, look into “a better route planner.” At $5 a month there is a cost (they have a yearly option too) but I tested that out and it does work. It could be worth it for those who are doing frequent road trips or using the car for extensive daily driving and prefer to be told when to stop so it takes the guesswork out.
It definitely updates from time to time, but it's not consistent. Right now, Apple Maps has my battery reading from 1 day ago.... not great.
I'll leave it alone and see how things go, but maybe they can fix the battery update issue.
