2013 RX450h New Car Features -- Complete Technical Listing
I've been doing some research in TIS attempting to identify details about my 2013 RX450h arriving in about 3 weeks. Anyway, as I've been scanning documents the last few hours, I thought it might be useful to others to provide extracts of sections of the various technical documents identifying the minute detail in each of the systems that were changed between 2012 and 2013 RX450h models. (Remember, this is not marketing info as to what features or options are packaged with what, but a technical view of everything the RX450h technically has to offer.)
I have listed all sections I found and indicate below with "no changes" where I didn't see anything of note. There were some big ah-ha's for me that we have not seen in previous publicized material such as the new Enform 2.0 Nav is a new HDD assembly behind the dash (hence why it can't be upgraded into 2010-12's), a new front proximity system to emit noise when running on electric only (no more stealth mode), some sort of 20-minute auto-off timer change to Smart Access, and other more minor tweaks across at least half the systems as we'd expect from Lexus. I read another thread a while back about the heated steering wheel, but can't seem to find it now -- the answer is, only the non-wood hand grip areas are heated from what I see in the diagrams.
Now, to head off the questions… I'm not an engineer or technical car guy, and don't have more information that what I've listed below, and I don't plan to renew my access to TIS. If someone needs an RX350 version of this or more technical detail than the extracts below, your best bet is to purchase your own 2-day access to the material here: http://techinfo.toyota.com for 15 bucks. It's pretty easy to get around in.
Happy reading! Enjoy!
LEXUS 2013 RX450H NEW CAR FEATURES
AUDIO / VISUAL / TELEMATICS
Audio & Visual System
2. MAJOR DIFFERENCE
(a) The 2013 models have been modified from the 2012 models as shown below:
(1) The design of the following items in the combination meter assembly has been changed:
• Hybrid System Indicator
• LCD (ODO/TRIP display and shift position indicator)
(3) The following functions that can be enabled or disabled in the electronic features control mode of the multi-information display have been changed:
• AFS ON/OFF Switch: Discontinued
• EV Mode Switch: Discontinued
(5) The text of the warning messages for the maintenance required reminder function, which are displayed on the multi-information display, has been changed.
(6) The display design of the headup display has been changed
Lexus Enform System
2. MAJOR DIFFERENCE
(1) The display and navigation module display has been combined with the radio receiver assembly, becoming integrated into the multi-media module receiver assembly.
(2) Due to the adoption of a new type HDD navigation system, the Apps service has been added to the LEXUS ENFORM.
Safety Connect System
2. MAJOR DIFFERENCE
(1) The safety connect system has been adopted on models with the Lexus display audio system.
(2) The display and navigation module display has been combined with the radio receiver assembly, becoming integrated into the multi-media module receiver assembly.
Garage Door Opener
2. MAJOR DIFFERENCE
(1) The location of the garage door opener switch has been changed to the area on the inner rear view mirror assembly.
Navigation System / Multi Information Display
2. MAJOR DIFFERENCE
(1) The DVD type navigation system has been discontinued.
(2) A new model HDD navigation system is available.
(3) The display and navigation module display has been discontinued. Instead, the multi-media module receiver assembly, which integrates the navigation ECU and radio receiver assembly, is provided
Blind Spot Monitor System
2. MAJOR DIFFERENCE
(1) The blind spot monitor system is available.
Intuitive Parking Assist System
2. MAJOR DIFFERENCE
(1) 2 front No. 1 ultrasonic sensors have been added on the front center portion of the vehicle, expanding the detection area of the intuitive parking assist system.
(b) The screen, which appears on the multi-information display and/or multi-display* when the intuitive parking assist system detects an object, has been changed.
*: Models with Lexus display audio system, 12-speaker surround sound system, 15-speaker surround sound system or HDD navigation system
Monitor System
2. MAJOR DIFFERENCE
(1) A monitor system has been adopted on the Lexus display audio system.
(2) The side monitor system has been discontinued.
Parking Assist Monitor System
2. MAJOR DIFFERENCE
(1) The side parking assist monitor system has been discontinued.
(2) The parking assist ECU has been integrated in the multi-media module receiver assembly.
(3) The parking assist monitor system is controlled by the multi-media module receiver assembly.
(4) The screen displayed for the parking assist monitor system has been changed.
BRAKE
Brake (Front) -- No changes
Brake (Rear) -- No changes
Brake Control System
2. MAJOR DIFFERENCE
(1) The brake pedal stroke sensor has been changed to a non-contact (semiconductor) type.
DRIVETRAIN -- No changes
Parking Break -- No changes
Axle System - No changes
Drive Shaft System - No changes
Hybrid Transaxle System - No changes
Rear Drive System - No changes
ENGINE / HYBRID / EV SYSTEM
Cooling System - No changes
Emission Control System - No changes
SFI System - No changes
Engine Unit - No changes
Fuel System - No changes
Exhaust System - No changes
Intake System - No changes
Lubrication System - No changes
Cruise Control System
2. MAJOR DIFFERENCE
(1) The warning indication on the combination meter assembly when a malfunction is detected in the cruise control system has been changed.
Dynamic Radar Cruise Control
2. MAJOR DIFFERENCE
Hybrid Control System
2. MAJOR DIFFERENCE
(1) Due to the adoption of the EV drive mode switch, the operation to enter EV drive mode has been changed.
(2) SPORT mode control is provided. This control increases the drive force provided by the vehicle during mid-range acceleration, enhancing acceleration response.
(3) An additional operation method of the emergency shutdown function has been provided, which stops the hybrid system when holding the power switch for approximately 2 seconds or the power switch is pushed 3 times or more in a row.
(4) The inverter water pump assembly has been changed.
POWER SOURCE / NETWORK
CAN Communication System
2. MAJOR DIFFERENCE
(1) The side parking assist monitor system has been discontinued, resulting in the parking assist ECU being discontinued from CAN communication system.
(2) The blind spot monitor system has been adopted, resulting in the blind monitor sensor added to CAN communication system.
LIN Communication System
2. MAJOR DIFFERENCE
(1) The automatic high beam system has been discontinued, resulting in the inner rear view mirror being discontinued from LIN communication
Multiplex Communication System
2. MAJOR DIFFERENCE
(3) In accordance with the change of navigation system and audio system, AVC-LAN communication system has been changed.
(4) The automatic high beam system has been discontinued, resulting in the inner rear view mirror being discontinued from LIN communication system.
Electric Power Control System - No changes
STEERING
Power Steering System - No changes
Heated Steering Wheel System
2. MAJOR DIFFERENCE
(1) he heated steering wheel system has been adopted
Steering Column System - No changes
Steering Lock System - No changes
SUSPENSION
Front Suspension System - No changes
Rear Suspension System - No changes
Tire and Wheel Type System
2. MAJOR DIFFERENCE
(1) Newly designed and painted wheels are available on specified models.
Tire Pressure Warning System - No changes
VEHICLE EXTERIOR
Fuel Lid Opener System - No changes
Power Back Door System
2. MAJOR DIFFERENCE
(1) The door lock request can be accepted and reserved while the back door is closing, improving usability of door lock operation.
Body Structure
2. MAJOR DIFFERENCE
(1) The design of the front headlights, front bumper cover, and upper and lower radiator grilles has been changed.
(2) An aero stabilizing fin is provided to enhanced aerodynamics.
(3) Performance dampers (front and rear) have been adopted for F SPORT.
Lighting System
2. MAJOR DIFFERENCE
(1) The exterior light design has been changed.
(2) The intelligent Adaptive Front-lighting System (AFS) and automatic high beam system have been discontinued.
(3) The battery saving function has been added to prevent the auxiliary battery from discharging when the headlights or taillights are left on.
Mirror System
2. MAJOR DIFFERENCE
(1) The new model HDD navigation system is available.
(2) The operation screen for the front wiper deicer system has been changed due to the change of the navigation system.
(3) The Lexus display audio system has been added to the available audio system.
Towing Converter System - No changes
Sliding Roof System - No changes
Vehicle Proximity Notification
1. OUTLINE
(a) When the vehicle is being driven quietly using the motor only, the vehicle proximity notification system outputs a warning sound from the vehicle approaching speaker assembly to inform pedestrians, cyclists, etc., of the approach of the vehicle.
(b) The warning sound is output by the vehicle approaching speaker assembly at a volume level that will not be perceived as noise. Also the pitch of the sound changes in accordance with the vehicle speed so that the sound reflects vehicle deceleration and acceleration.
(c) Vehicle proximity notification system operation automatically stops when the vehicle is stopped, the engine starts or the vehicle is driven at 20 km/h (12 mph) or higher
2. MAJOR DIFFERENCE
(1) The vehicle proximity notification system has been adopted.
Power Window Control System - No changes
Windshield / Window Glass System
3. MAJOR DIFFERENCE
Wiper and Washer System - No changes
VEHICLE INTERIOR
Power Door Lock Control System - No changes
Heating / Air Conditioning System
2. MAJOR DIFFERENCE
(1) The design of the air conditioning control panel has been changed.
Lighting (Interior) System - No changes
Meter / Gauge System
2. MAJOR DIFFERENCE
• Indicator and warning light layout
(2) A function that changes meter panel illumination color in accordance with the vehicle driving conditions has been added.
• Sport Mode Switch: Added
(4) Blind spot monitor system related warning messages have been added to the warning messages displayed on the multi-information display.
(6) The display design of the headup display has been changed.
Power Outlet Socket System - No changes
Pre-Collision System - No changes
Climate Control Seat System - No changes
Power Seat Control System - No changes
Seat Assembly - No changes
Seat Heater System - No changes
Airbag System
2. MAJOR DIFFERENCE
(1) The record data item of the event date recorder (EDR) has been increased.
(2) The side airbag sensor (for center pillar) has been discontinued.
(3) The operating condition of the seat outer pretensioners has been changed.
(4) The design of the steering pad (driver side squib) has been changed.
Occupant Classification System - No changes
Engine Immobilizer System - No changes
Smart Access System
2. MAJOR DIFFERENCE
(1) The time setting of 20 minutes for the automatic power off function to operate when the power switch is on (ACC) has been added.
(2) An additional operation method of the emergency shutdown function has been provided, which stops the hybrid control system when the power switch is pressed 3 times or more in a row or pressed for 2 seconds or more.
(3) The duration of the door ajar warning buzzer and key left in vehicle warning buzzer have been changed to 5 seconds.
Theft Deterrent - No changes
Excellent and very comprehensive post.
Thanks
Locking the car while the lift gate is closing will save me 5-7 seconds every day.
Wish AFS and auto dimming were still available. Fair trade for blind spot??
No illuminated garage door buttons.
No EV mode, only worked one out of ten times for me anyway
No stealth mode.
Where is the aero stabilizing fin?
(use as needed)
EV mode stills exists. It now has a dedicated switch I believe to the right of the steering wheel console. You just don't get there through use of the mode selector any more.
Auto Power Off. When the vehicle is in Park and ON, vehicle turns itself off after 60 minutes. When vehicle is in Park and ACCESSORY mode, vehicle turns itself off after 20 minutes. (Those people who have complained about their inadvertent leaving the car on should be happy about this as well as the longer duration buzz when you open the door and the car is on...)
New DVD player without RSES: DVD video can be played when vehicle is stopped, is ON or in ACCESSORY, and parking brake is on. If driving and one attempts to play a DVD, only the audio heard.
Stealth Mode does appear to really be gone. I don't find any option available to the customer or dealer that can turn off the new Vehicle Proximity Notification System (aka the beeping when Going slow in electric only mode).
I'm thinking of including the Blind Spot Monitor in my special order when I pull the trigger. I saw a nice video of the system in action (on a 2013 ES) over at lexusenthusiast.com. Here's a link.
Functionality seems perfect. Only open switch for me would be how the sensors are mounted -- looks like on inside of the bumper from diagrams I saw earlier today on TIS and the area they sensing, but given that Lexus Intuitive Parkiing Assist has very noticeable external spots for it's sensors (unlike some OEM versions such as my 2009 BMW where they were 100% hidden from view), I'd like to know that point. It's at least something for you to consider.Can't wait to hear of your order, and better yet, your DELIVERY!
I was wondering why the comfort package is so much cheaper, and why the reference to AFS was gone when selecting the option.
At least Lexus made the comfort package cheaper, so it all balances out.
We are also waiting for our 2013 RX 450H Stargazer Black. It will be our first H, we had the first 350 in Seattle back in the 90's and just traded in our 2008. Anything I should know before we drive it off the lot in a few weeks?
(I'll get pics and initial comments up on my 450h within a couple days of it's arrival next month, and watch the forum for others that may be bringing one home in the meantime!)
I just bought the 2013 rx350. I have a question that u may be able to answer. There is no digital speed displayed when u set the cruise. Is this a bug in the new car or is this normal. I thought every new 2009- present Lexus had this feature. My other Lexus ISF has this feature. The owner manual shows one picture with the speed displayed digitally but it is regarding the 450H. Any explanation? Thanks. Adam.
