Ancel BS200 Bluetooth Jump Starter
Note:
Ancel says this is only compatible with vehicles that use the 12v battery to directly start the engine. That means it is not compatible with Lexus/Toyota hybrids.
It is a Bluetooth enabled super-capacitor powered permanently mounted jump starter.
It has a claimed life of 100,000 cycles and should not suffer degradation over its life, the way that a battery-powered jump starter will. It also alleviates any fears of a battery fire, though LiFePo fires are very rare. The downside of the super-capacitor is that it does not have nearly as much capacity as a battery powered jump starter though this may not matter in a practical sense. I watched several videos on youtube where it quickly started vehicles with dead or near-dead batteries, one in winter weather.
It has a built-in 12v battery monitor so one does not need to buy a separate monitor. The monitor includes battery history and shows starting voltage at a millisecond level as well . The app supports multiple jump starters.
It automatically boosts the battery when starting but also has a "Force Start" mode for when jump starting a dead battery. The automatic boost feature is what caught my eye. I have a GR Corolla, which has a high-compression engine with a small rear-mounted battery, the same battery that the RX450h+ uses. My Ancel BM300 Pro shows a large voltage drop when starting, though the battery checks out as very healthy and starts the engine with no issue. With the BS200 temporarily mounted using the included clamps, it reduced the voltage drop by 1.5 v when starting, eliminating the sharp dip.
I am not impressed with the included clamps. There are no instructions on how to use them and it seems that you just clamp the spade terminals to the battery terminals, not the best connection or very secure, though it seemed to work.
I plan on permanently mounting this in my GR Corolla and getting another for my Ford Focus. I already have an Ionic Emergency Start in the RX450h+ and am satisfied with it for now,
Ancel BM200 temporarily attached to GR Corolla battery
Without BS200 attached.
With BS200 attached.(From BM300 Pro) The BS200 has a display like this as well.
App showing BS200 Charging. It took about 8 minutes from completely dead. It can also be charged via USB-C, in about an hour.
Starter tab, showing current capacity and voltage as well as number of assists and last discharge amps.
Battery tab, showing both battery and BS200 stats.
Battery Tab, showing last start stats
Popup after starting.
ANCEL BS200 Super Starter Instant Start Smart App Monitoring
Here is a more closeup photo showing the temporary mount using the included clamps.
I’m a bit confused about what would help me best if my 12V starter battery dies and I get locked out.
Currently, I have the BM300 Pro monitoring device, but it doesn’t provide any jump-start capability. Then there’s the ANCEL BS200, which helps protect and preserve the 12V battery, and also the Ionic Notstart system.
Can anyone share practical experience or advice on which option works best when the 12V battery is completely dead? What would you actually rely on in real-life situations to avoid getting stuck?
Thanks in advance!
With the Ionic, one activates it, unlocks the door with the fob, then starts the engine or hybrid system and this has been proven to work.
Wells? What are your thoughts? Yea or Nay on the BS200 for the RX hybrid? I was ready to pull the trigger.
I’m still not sure why it wouldn’t work for the hybrid. I understand that it would not provide an emergency remote start vs the Ionic. But the Ancel should go a long way in preventing the need for an emergency start in the first place by keeping the battery strong.
