Bad Injector in 2024 RX350
Old Oct 21, 2025 | 09:50 AM
toupslexus's Avatar
toupslexus
10th Gear
Angry Bad Injector in 2024 RX350
My nearly two year old RX350 needs a new injector in the engine. How is this possible and should I worry that there will be additional problems? I had an 2015 RX350 for nine years and never had a problem. Unbeleivable.
Old Oct 21, 2025 | 11:30 AM
mikemu30's Avatar
mikemu30
How is it possible??? NEW means Never Ever Worked. It's quite possible Lexus or any other brand. Good news is you have a warranty.
Old Oct 21, 2025 | 05:01 PM
Carbuff2's Avatar
Carbuff2
Do you use Top Tier gasoline? That helps to keep injectors clean.
Old Oct 21, 2025 | 07:04 PM
kry226's Avatar
kry226
Anything mechanical can and does go bad, but seems like a fluke. You'll probably never have this issue again for the rest of your life.
Old Oct 22, 2025 | 05:36 AM
toupslexus's Avatar
toupslexus
10th Gear
Always premium but I do vary amongst providers. Do you recommend a certain brand?
Old Oct 22, 2025 | 06:11 AM
autotech13's Avatar
autotech13
I would use Shell. I've been using Shell for over 50 years now and have had no fuel problems.
Old Oct 22, 2025 | 06:39 AM
toupslexus's Avatar
toupslexus
10th Gear
Thank you!
Old Oct 22, 2025 | 07:26 AM
WellsB's Avatar
WellsB
I've been a refinery engineer since 2008. I mostly use Costco gas, but occasionally run Shell and Chevron. Each has a different additive that is beneficial and all three are top-tier.
In the past 25 years of owning fuel injected vehicles, I have never had a fuel injection related issue and I seriously doubt that the brand of gas had anything to do with your fuel injector failure. My guess is that it was just a manufacturing defect.
Old Oct 22, 2025 | 08:43 AM
toupslexus's Avatar
toupslexus
10th Gear
Thank you! I am hopeful this is a one off issue as reliability and low maintenance were my number 1 reasons for purchasing a Lexus.
Old Oct 22, 2025 | 09:42 AM
mikemu30's Avatar
mikemu30
exactly about zero chance it was fuel brand.
Old Oct 22, 2025 | 05:29 PM
Freds430's Avatar
Freds430
Major top-tier gasoline brands76, Arco, Chevron, Conoco, Costco, Exxon, Marathon, Mobil, Phillips 66, Shell, Sunoco, and Texaco.
Old Oct 23, 2025 | 05:19 AM
PortStLucieRX350's Avatar
PortStLucieRX350
Exactly. I had a 2019 Jeep Grand Cherokee that had to have a cylinder head replaced at 400 miles. Turns out the valve channel wasn't bored to spec during manufacture and was slightly narrow, so every time the valve heated up and expanded it would get stuck open. Once they replaced the head I never had another issue with the engine. Manufacturing, even in the best factory, isn't 100%. You just won the wrong lottery by getting that 1 in 1,000 part that was bad.
toddharshm
RX - 4th Gen (2016-2022)
Dec 22, 2024 11:04 AM
shoalsgary
Nov 14, 2024 03:38 PM
pauljcl
Feb 29, 2016 01:49 AM
cdrx350
Nov 10, 2007 05:52 PM
jimmyzhu
Jun 22, 2006 11:11 AM
