Engine break in on Rx 350H?
Old Aug 16, 2025 | 06:08 AM
wowzer's Avatar
wowzer
Default Engine break in on Rx 350H?
Is there a break in recommendation for the 350H? If not, what do yins do during the first 1,000 miles? I usually wont accelerate too hard and change the oil after 1,000 miles.
Old Aug 16, 2025 | 06:15 AM
SonOfABisc's Avatar
SonOfABisc
If only manufacturers published some sort of manual with information like this, and gave a copy to buyers. If only.
Old Aug 16, 2025 | 06:31 AM
Carbuff2's Avatar
Carbuff2
If changing the oil makes you feel better helps you to sleep at night, DO IT. Being gentle initially is good, too.
With ICE engines, hard acceleration or constant RPM driving is discouraged during break in...but on a Hybrid it's kinda out of your control, isn't it? Now you know why I turned on the tachometer display on our 500h.
Old Aug 16, 2025 | 02:16 PM
Eagleboy99's Avatar
Eagleboy99
Drive it like you stole it. We do that for boats and they last for decades.
Old Aug 17, 2025 | 05:06 AM
Sonny3621's Avatar
Sonny3621
I don't think any of that really matters. Plus I'm not changing my oil until the first recommended interval at 10K miles. In the real world that doesn't matter either IMO.
Old Aug 17, 2025 | 07:16 AM
toyotaman7's Avatar
toyotaman7
They should give you a black folder with a book inside called owners manual. In the there is a section specific to break-in period
Old Aug 17, 2025 | 07:55 AM
autotech13's Avatar
autotech13
Remind me when you sell or trade in your car, so I can stay far far away from it when buying my next car!
Old Aug 17, 2025 | 08:05 AM
Sonny3621's Avatar
Sonny3621
So you are saying you will stay "far far"away from any car that the owner has followed the manufacturer recommended service intervals? That's brilliant 🙄
Old Aug 18, 2025 | 07:04 AM
wowzer's Avatar
wowzer
this is in the manual, but with few specifics:For the first 1000 miles (1600 km):
• Do not drive at extremely high speeds.
• Avoid sudden acceleration.
• Do not drive continuously in low gears.
• Do not drive at a constant speed for extended periods.
what is extremely high speeds? 75mph? 85 mph?
how do I avoid driving continuously in low gears?
what is extended driving in duration? 1 hr? 30 min? 4hrs?
I wasn’t sure what/how to avoid some of these things…
Old Aug 19, 2025 | 05:20 AM
Universe93's Avatar
Universe93
You know, the reality is the majority of owners follow the maintenance schedule or don't follow it at all. So when you buy a used car or even CPO, it is an oil change every 10k miles. Only people like us who bother to even go to an internet forum for a particular model vehicle, are annoying about this kind of stuff.
Old Aug 19, 2025 | 06:20 AM
Sonny3621's Avatar
Sonny3621
Those guidelines are very general and are pretty much saying just use common sense in how you drive. Pretty much just go the speed limit and drive normally and you are good. Anybody who buys a pre-owned or CPO has absolutely no idea how the previous owner drove the car in the first 1,000 miles anyway so don't even worry about it. It's a non issue. Lexus recommends oil changes at 10K miles so for me 10K miles it will be. If somebody else's opinion differs then that's on them. If my engine implodes at 50K or 100K miles it won't be bc I drove normally for the first 1,000 miles and then changed the oil at the factory recommended 10K mile intervals.
Old Nov 2, 2025 | 03:20 PM
Penurious's Avatar
Penurious
1st Gear
Page 184 of Owners Manual for 2026 RX350h owners. I’d imagine the same for all Gen 5 Owners.
Breaking in your new Lexus
To extend the life of the vehicle, observing the following precautions is recommended:
For the first 200 miles (300 km):
• Avoid sudden stops.
For the first 500 miles (800 km):
• Do not tow a trailer. (vehicles with towing package)
Old Nov 2, 2025 | 04:47 PM
RealWing's Avatar
RealWing
You need to do several accelerations to apply sufficient radial load to the piston rings to aid in seating the rings to the cylinder bores. Periodic acceleration pulls at abt 75% throttle is a good guideline while keeping rpm’s below abt 75% of redline. Running at a constant speed applies very little radial force on the rings.
having said that, most modern engine cylinders are machined to very exact tolerances and typically require less breakin than older engines.
Jim
Old Nov 3, 2025 | 06:23 AM
Universe93's Avatar
Universe93
I thought boats were a hole in the ground that you pour money into? Maybe I'll try your method.
For modern vehicles, don't hot dog it for 700-1000 miles and then nobody cares. I bet most people don't even do that. For vehicles off the lot, I bet other people who test drive that vehicle that you later bought - I'm sure they pushed it quite hard.
Old Nov 3, 2025 | 06:31 AM
PortStLucieRX350's Avatar
PortStLucieRX350
Actually that's an inground pool (I know because we have one!). A boat is a hole in the water you pour money into. Different holes, same result
