At what pressure does TPMS alert?
When it drops below X number of psi the light will come on. What is X in PSI?
in my ES which I've owned for six years now, the moment any single tire drops below 30 psi, bingo light comes on.
\initialized the system on all of them. What is the pressure listed on the inside of your drivers door and do you keep it set to that?
The low-pressure threshold is generally 6 psi below set pressure.
An improvement with the latest generation RX and NX is that you have a choice during the initialization process of setting to indicated tire pressure (door placard) or set pressure (current tire pressure).
This is a useful tool for technicians, customers often have the low-pressure thresholds set way out of range and selecting "set indicated air pressure" can be performed without having change the actual tire pressure in each tire.
I get what you are saying but I guess you've never set it yourself. That number is customizable and not a fixed number. I've owned many Toyota products and have
But one thing I noticed about the Tire Pressure readings on the Lexus app is that they always show a higher pressure. I just assumed that the app is reading the 'hot' pressure, as occurs during driving.
you mean the app as opposed to the screen inside I presume. Im not sure the app can read cold psi at least until the car is driven a mile or so.
Won't look at the in-car warning unless it actually tells me that there is an issue (low pressure).
But I DO like to be informed as to how the tires are doing, so I will occasionally look at the pressures on the Lexus app.
Mar 1, 2022 10:01 AM
