Dead 12v battery Incident (merged threads)
Or is there a similar trickle charger similar to what folks use in extreme cold environments that will keep the battery charged.
Next week we are out of town for 8 days, and I guarantee it will be dead when we get back, which will make my third time in the four months we've owned it. I am prepared to just sell it and move on from Lexus. This was our first (we've owned Toyota's for 10yrs) and never experienced these problems with any other vehicle.
The Genius5 operating temperature is listed as: -4°F to 104°F (-20°C to 40°C)
If you expect to use it regularly on a specific car Noco has accessories, including ring-terminal leads/. For a non-hybrid vehicle you can put the ring terminals on the two battery clamp bolts so you aren't mucking around with the alligator clips.(leave the cable in place, it has an integrated cap for when it isn't in use, then connect/disconnect the Noco using the quick-connect clip that is on the lead coming out of the charger)
If I had to do it over, I wouldn't buy a Lexus
Not because of the 450H+, but the larger lack of customer focus, and a highly lethargic/reactive attitude to problems by the company.
So... next week, when we are out of town for 8 days, it will likely be a paper weight when we come back. I'll call Roadside, jump it again and just drive to the Dealer and tell them to leave it sitting for 3 days.
If that fails, then I will start the process with my NJ state Lemon Law program and go from there.
If buying a Noco5 works, then I am all for it, I like the RX 450h+ and my wife loves it, it's the damn drain issue that's killing it for us.
I also noticed that in addition to the battery connection accessory wire, they also sell a 12v cigarette lighter adapter as well. Maybe less fussing with the battery leads going that route.
First set up, as I have to back my RX into my garage it was not a convenient set up for me due to the location of the electric outlet. With careful placement the back door closed on the cable without any noticeable pinching.
Current set up with a installed OEM trickle charger, super convenient, but over priced should be part of the factory build.
Cheers
Cheers
