Lug bolt Engineering!
Old Aug 13, 2023 | 12:21 PM
lexusnyca's Avatar
lexusnyca
Yes, its a 14x1.5, I ordered a metal one today from amazon to toss into the spare tire toolkit. Those 21" wheels/tires are hard enough to handle, even with a proper guide, especially for a roadside tire change due to a flat.
Old Aug 13, 2023 | 07:06 PM
2023RX350PP's Avatar
2023RX350PP
Lexusnyca, did the metal guide you purchased from Amazon fit correctly? Which one did you order? Thanks.
Old Aug 14, 2023 | 06:51 AM
lexusnyca's Avatar
lexusnyca
I haven't gotten it yet. I ordered this one:
Amazon Amazon
Old Aug 15, 2023 | 08:53 AM
E46CT's Avatar
E46CT
Interesting i haven't seen that. this design probably means less wear and tear on the wheel from repeated fastening. if you look at any BMW that has had its wheels off and on, you'll see that part of the wheel ground down from repeated tightening. still works.. just unsightly..
i know the supra and IS (a long time ago) adopted plain BMW/german style bolts with no independent collar/head thingy, so did they switch to this *even newer* bolt design?
Old Aug 17, 2023 | 12:44 PM
CAPTBob's Avatar
CAPTBob
I ordered that one also. I just got it today and the diameter and threads are an exact match for the resin one under the rear mat next to the spare tire. So it is now nestled back there, hopefully never to be used.
Old Aug 17, 2023 | 06:07 PM
2023RX350PP
Just ordered mine as well. Thanks for the update
Old Sep 16, 2023 | 01:09 PM
happy1977's Avatar
happy1977
Default wheel hanger stud pilot pins
Does anyone here know what size are on the RX? Thinking of getting these for easy wheel mounting.
Just found out that ours comes with 1 guide pin after ready the manual.
Old Sep 16, 2023 | 02:08 PM
LARRX350's Avatar
LARRX350
Check out this thread, mounting bolt specs listed and a link to more wheel hangers.
Wheel studs and hangers
Old Sep 16, 2023 | 02:48 PM
lexusnyca's Avatar
lexusnyca
See post #18, the factory guide pin is plastic.
Old Apr 20, 2024 | 06:19 PM
Grahaminat's Avatar
Grahaminat
Has anyone replaced the lug bolts with a set of traditional lug studs and nuts? I've tried several wheels, including the 4th Generation RX350 F-Sport black wheels on my 5th Generation RX, but was told the lug bolts "wouldn't work" because of the way they're "seated."
I'm seriously thinking of removing all the lug bolts, replacing them with traditional studs & nuts so I can use different wheels.
Can anyone tell me why I should not or could not replace the lug bolts with traditional studs?
Thanks in advance.
Old Apr 20, 2024 | 07:39 PM
Urlik's Avatar
Urlik
There really is nothing much negative about switching to studs other than a very minor increase in unsprung weight that a wheel may compensate for anyway. Finding everything you need to make the swap may be a little challenging.
Old Apr 21, 2024 | 07:23 AM
StefanoS's Avatar
StefanoS
I bought two of these pins to carry in my cars, just to make life a little easier for a wheel/tire change. They're stainless steel and they work well.
Amazon Amazon
Pittsy
Nov 22, 2022 02:42 PM
ssis300
IS F (2008-2014)
18
Aug 31, 2017 01:15 PM
1013mm
Wheels, Tires & Brakes Forum
Feb 5, 2010 06:47 PM
TBONE1904
16
Apr 15, 2004 01:22 AM
is300lexusgirl
May 17, 2002 10:22 AM
