Trunk lock issue
Old Jun 23, 2023 | 02:51 PM
daryll40's Avatar
daryll40
Close and Lock still fails to work with the Digital Key; only with the FOB.
Old Jun 23, 2023 | 02:55 PM
Urlik's Avatar
Urlik
While it would make it virtually useless if this works since there is a button, have you tried it with the digital key while standing behind it? If it does work, something else to add to the software change thread.
Old Jun 23, 2023 | 03:57 PM
daryll40's Avatar
daryll40
Does not work.
Old Jun 24, 2023 | 12:15 AM
Dhill's Avatar
Dhill
In the 2023 RX Deep Dive video (Part 1), she does say you will need the key fob with you in order for this to work.
Old Jun 24, 2023 | 04:20 AM
daryll40's Avatar
daryll40
But nowhere does she say that this won’t work with the Digital Key. Her “you need a key FOB” for this to work implies that it should work with the Digital Key too. Put another way, it’s hard to imagine that this isn’t a software error. Why would Lexus purposely design an advanced close feature and an advanced Digital Key, but also purposely design them to be incompatible?
Old Nov 22, 2025 | 08:12 AM
MrLexus07152125's Avatar
MrLexus07152125
1st Gear
Default This works!
I had the same issue and after trying what this said, it works!!
Originally Posted by toyotaman7
I think I read somewhere that after pressing the button the car beeps once, if you have the key you should step away enough for the door to clear, but not walk away yet. It will then beep twice. As long as your key is detected at this point it will continue and then lock. Should be able to walk away from the vicinity of rear hatch after the second beep. At least this is what I remember reading.
Old Nov 22, 2025 | 08:19 AM
daryll40's Avatar
daryll40
Wow, you revived this very old thread. What you said is indeed how it works. My issue was with the "Digital Key" on your phone. It never worked right with the rear hatch lock and walk. I finally gave up on the whole Digital Key thing and just carry the FOB. Maybe they've finally improved the Digital Key, and maybe I should take a look after about 2 years since I gave up. My now-almost-three-year-old RX350h has been great (although I only drive 5000 miles/year) overall. But the Digital Key was a failure. There should have been a class action suit and Lexus should refund the few hundred dollars they charged for this. But I have bigger fish to fry.
Floyd76b
Nov 10, 2018 08:49 AM
Onoyme
Jun 8, 2008 02:33 PM
camerri
Oct 13, 2007 12:01 AM
