Wireless Charging Issue
Old Apr 22, 2023 | 11:13 AM
JohnPDX's Avatar
JohnPDX
Originally Posted by bdspilot
I have an iPhone 14 with apple MagSafe case and it charges slowly. I slide the case all the way forward. I notice when I put the phone on the charger there is a clicking sound like something is trying to align.
From page 405 of the RX User Manual:
"When the charging coil inside a portable device is detected within the charging area, the charging coil in the wireless charger will move near the other coil and charging will begin. If the charging coil inside the portable device is moved out of the charging area, charging will be stopped automatically."
See pages 406 - 410 of the RX User Manual for troubleshooting and other tips on this topic.
Old Apr 24, 2023 | 03:09 PM
winpakbob's Avatar
winpakbob
While this would have been a nice feature, the wireless charger is useless on my Samsung Galaxy S22 Ultra with a very thin case. Just the camera bump lifts the phone up enough to pretty much make it useless. I bought a 12" dual right angle USB C cord and just plug it in.
2023 350h Luxury
Eminent White Pearl - Macadamia/Birch
Old Feb 8, 2024 | 07:53 PM
dreamG's Avatar
dreamG
Default Wireless 🛜 phone charging
How is your wireless phone charging in the car going with the new RX? I have an iPhone 15 with a thin MagSafe case and the wireless charging is almost non-existent. It barely goes up 1 or 2 percent after 10-15 minutes of constant charging. The car is RX500h. Please share your experience. Thank you.
Old Feb 8, 2024 | 08:03 PM
HeyThere's Avatar
HeyThere
It flat-out doesn't work. The dealership said it wasn't meant to charge. It just maintains.
It's the only thing that disappoints me about the vehicle. It doesn't charge at all
Old Feb 8, 2024 | 08:43 PM
Ascho's Avatar
Ascho
Agreed. They told me the same thing. I don’t understand how it works so well on my previous Cadillac but so poorly on my Lexus Rx 350h
Old Feb 10, 2024 | 06:55 PM
WellsB's Avatar
WellsB
The one time I tried it, because there was water in my charging port, the phone got so hot that the battery would not charge. On the plus side, my charging port dried out quickly...
Even with good wireless chargers, they heat up the phone and battery, shortening the battery lifespan. I don't use them for that reason.
Old May 16, 2024 | 10:32 AM
Igorwd's Avatar
Igorwd
4th Gear
Default Wireless charging fixed
Originally Posted by NextLexus
Is the wireless charger on RX 350h a joke? I could not get my iPhone 11 charged constantly. It will stop working after a few minutes of charging. I had to pick my phone up and set it back on, but it would fail again. Kind of annoying .. just wonder anyone had the same issue. Thanks for help!
I finally permanently fix wireless charging on my lx600 I switched original Panasonic charger witch was showing charging on and off ,I switched inside to Samsung super fast 15watt charging board. Now i can put my phone any position even at angle and is charging 100% no issue
after with fat case
https://youtu.be/Al4LMYvrIx0?si=8fc44_t98k73L_bJ
Old May 16, 2024 | 10:49 AM
chuckNX's Avatar
chuckNX
The wireless charging works fine for me. However, it is important to note that your charging experience will vary based on usage.
For example, if you turn off WIFI (force CarPlay not to connect), the phone will charge the fastest.
If you are trying to run CarPlay, use phone maps for navigation, and wireless charge at the same time, the wireless charging will appear to not be working when it can barely keep up with the energy requirements for apps running on the phone. Also, the phone will/may run hot, especially on warm days, which may cause a blinking light in which it refuses to charge. I have not seen this written anywhere, just my experience.
I experienced the exact same thing when I had my 2021 RX450H.
Wireless charging works if you don't use the wrong type of case, and don't expect to max out your phone CPU while you are charging. In which case you may want to charge via the USB instead.
I wish the iPhone was smart enough to provide a pop-up that explains the limitations so people don't automatically think wireless charging is broken.
Old May 16, 2024 | 10:57 AM
Igorwd's Avatar
Igorwd
4th Gear
Default Replacement Independent wireless charger inside lexus
Old May 16, 2024 | 11:07 AM
chuckNX's Avatar
chuckNX
there are several threads about the LX charging base being too small for new phones. That’s a common problem.
although the guy in the video found a very expensive workaround, which is a shame you have to do that at all.
Old May 17, 2024 | 05:26 AM
Carbuff2's Avatar
Carbuff2
Even if you just turn off the screen on the phone? The screen is the biggest current draw.
the display is still visible on the MM Carplay screen even with the phone's screen OFF.
Old Jul 5, 2024 | 04:15 PM
AznD85's Avatar
AznD85
Default iPhone 14 Pro - Wireless Charging Help
New Car owner here for the 2024 RX350H Premium+
I placed my iPhone 14 Pro into the wireless charging area and it shows it's charging but I'm using Waze on my iphone connected to the car and it doesn't seem like it's really charging since the battery is kind of still depleting but maybe more slowly.
Is this normal?
Old Jul 5, 2024 | 04:24 PM
Urlik's Avatar
Urlik
Yes, the wireless charging isn’t enough for things like that. We did a 8 hour drive last week and eventually plugged the phone into a USB C port to get it charging more than it was using. It probably would have lasted the drive but plugged it in anyway.
Old Jul 5, 2024 | 07:45 PM
Ascho's Avatar
Ascho
Embarrassing what a poor job it does, especially when you see how good it can be on other cars
Old Jul 5, 2024 | 07:57 PM
Urlik's Avatar
Urlik
They chose to put in a low wattage wireless charging pad. Although wireless will not beat wired.
https://www.clublexus.com/forums/rx-...ing-issue.html
