Toyota/Lexus Safety Recall -
FYI Everyone -
Toyota Motor Company issued a safety recall for certain Toyota and Lexus vehicles over a faulty vacuum pump assembly, which helps with braking assist.
The recall involves about 6,000 2018 Toyota Camrys and Highlanders, as well as Siennas, Tacomas and Lexus RX350s from the 2017 model year. Only models equipped with a vacuum pump assembly are affected.
A part of the assembly may have been built wrong, which can cause a warning light, message or sound to go off, or a sudden loss of braking assist. Left unfixed, the affected vehicles have an increased risk of crashing.
ravenuer (05-02-18)
2017 RX Recall
I just learned about this:
NHTSA Vehicle Safety Recalls
- Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain 2018 Toyota Camry and Highlander vehicles, 2017 Toyota Sienna and Tacoma vehicles and 2017 Lexus RX350 vehicles. During the manufacturing process, the oil galley in the rotor for the brake booster vacuum pump assembly may have been improperly machined possibly resulting in a sudden loss of brake assist.SummaryRecall Number18V211000Recall Date04/03/2018ComponentSERVICE BRAKES, HYDRAULIC:POWER ASSIST:VACUUM
ConsequenceA sudden loss of braking assist can increase the risk of a crash.
What Owners Should DoToyota will notify owners, and dealers will replace the brake booster vacuum pump, free of charge. The recall began on May 9, 2018. Owners may contact Toyota customer service at 1-888-270-9371, or Lexus customer service at 1-800-255-3987. Toyota's numbers for this recall are J0K/JLD.
CharmCtyIS (11-05-18)
Thanks for updating. I hadnt seen this but dealer called me just today.
Hi, Thanks for the heads up. Although my 2018 RX doesn't have this issue, this make me curious and see if mine has any recall. In process of looking, I did see that there was a "Special Service Campaign" for the car's ICS. I confirmed this by logged into Lexus Driver web site.
https://drivers.lexus.com/lexusdrive...ortLandingPage
Here's a description of it:
Title: Special Service Campaign JLH - Remedy Notice Certain 2018 Model Year LS 500/500h, NX 300/300h, RX 350L/450hL Certain 2017-2018 RX 350/450h Intelligent Clearance Sonar (ICS) Reprogram
Status: Remedy Available
Description:
The involved vehicles are equipped with Intelligent Clearance Sonar (ICS). Due to improper software programming in the ICS system, the ICS system may improperly activate when an involved vehicle enters certain types of car wash facilities and is placed into neutral. If the ICS system activates, ICS system will exhibit warnings and the system may apply the brakes.
Remedy:
Before you are inconvenienced by this condition, any authorized Lexus dealer will reprogram the involved ICS Electronic Control Unit software free of charge.
Campaign Date
October 31, 2018
Dealer Reference ID:
JLH
Description:
Remedy:
Campaign Date
October 31, 2018
JLH
ravenuer (11-07-18)
2018 RX Recall?
Dealer called me stating there is a recall on my 2018 RX. Something to do with the brake booster.
I did a search online to confirm. I found a recall on the 2017 RX for the brake booster issue along
with other Toyota models, but nothing on the 2018 RX.
Anyone know anything about this?
Thank you.
Thank you.
Description:
Remedy:
Campaign Date
October 31, 2018
JLH
Description:
Remedy:
Campaign Date
October 31, 2018
JLH
