techstream version for 2019 Rx350
Old Feb 18, 2022 | 08:29 AM
jaso's Avatar
jaso
10th Gear
Default techstream version for 2019 Rx350
Hi everyone, I want to buy Techstream on eBay or Amazon. Which version should I buy for 2019 RX350? Thanks
update: My EPB malfunctioned after trying to replace the rear brake pads myself.
I have purchased a VXDIAG VCX NANO for TOYOTA TIS Techstream. It's perfect. The EPB is working now.
Old Feb 21, 2022 | 08:47 AM
sz8's Avatar
sz8
I got one with Mini VCI cable of version 1.4.1 and techstream of ver 12. I used it for programming a new key fob of my 2013 RX and to disable auto steering wheel tilting for my 2017 RX with no issue. However, it does not work on showing live data for either of my Lexus cars.
I don't think one version is always better than others. You probably just need to pick up one with most positive reviews and try that out. Please report back the results. Thanks.
Old Feb 21, 2022 | 11:17 AM
jaso's Avatar
jaso
10th Gear
Thank you. I have ordered one yet. I will report back the results here.
Old Feb 28, 2022 | 01:50 PM
jaso's Avatar
jaso
10th Gear
I read a lot of reviews, I got a VXDIAG VCX NANO for TOYOTA TIS Techstream from eBay $78+tax today. It is working perfectly. I have successfully cleared the electronic parking brake malfunction.
Old Apr 25, 2022 | 08:38 AM
MrChan's Avatar
MrChan
Do you happen to know if that product would work for a 2021 RX350L?
Old Apr 25, 2022 | 10:15 AM
sz8's Avatar
sz8
Default Thanks for the feedback Questions: Is the live data working? What is TIS SW version?
The connector looks very different than those sold on Amazon. Wondering if this is a better one.
Old Apr 25, 2022 | 12:09 PM
jaso's Avatar
jaso
10th Gear
I think it is better than Mini-VCI. I've been using offline mode because of the poor wifi performance of my old laptop. I am not sure the live data is working, let me try next time. The TIS version is V17.00.020.
Old Apr 25, 2022 | 12:13 PM
jaso's Avatar
jaso
10th Gear
I think it will work for all 2021 Toyota and Lexus models.
Old Apr 25, 2022 | 01:17 PM
MrChan's Avatar
MrChan
Thank you. Do you still have the link to that eBay listing?
I'm also experiencing an Electronic Brake Malfunction Error after trying to replace the rear brake pads myself, but I assume I just need to reset the memory or something.
Old Apr 25, 2022 | 02:27 PM
jaso's Avatar
jaso
10th Gear
You did the same thing as me.
You may search on eBay for " VXDIAG VCX NANO Diagnostic Tools for Techstream Compatible with SAE J2534 ", and choose a top seller, it is about $79. Please ask the seller to confirm it is compatible with the 2021 Lexus models.
Also, if you live in Queens,NY, I can bring it to help you on weekend.
Old Apr 25, 2022 | 02:32 PM
Quantum501's Avatar
Quantum501
Can you elaborate on the EPB malfunctions? ie...how did you retract the parking brake and do you know what caused the malfunction. I like to do my own brakes and curious what triggered the error.
Do you trust this software? I have heard some bad stories regarding this software and problems with virus and computer intrusions. TIS is great but I have only been doing the 2 day access. Would love to have it full time but concerned with safety for PC
Old Apr 25, 2022 | 02:52 PM
MrChan's Avatar
MrChan
I appreciate that very much, I'm from Brooklyn so I'ma see if the dealership will fix it under warranty before going another route.
Old Apr 25, 2022 | 03:16 PM
sz8's Avatar
sz8
Default Live data means the running data from the car. It should not
have anything to do with WIFI. For example, when changing the transmission fluid, live data can provide real time temperature of the fluid so the amount of new fluid can be added accurately.
Also, I thought changing the rear brake pads is simple. Just use any 9v battery to retract the EPB brake and do the rest. Does that procedure trigger an error? Thanks.
Old May 2, 2022 | 07:36 AM
jaso's Avatar
jaso
10th Gear
Whether using the 9V battery or putting it in service mode, my rear parking brake doesn't fully retract, I still can't install the brake pads. I need to manually push the piston back and EPB malfunctions.
I can't tell if this software will be a problem, so I installed it on an unused old laptop (win 10)and it's been fine so far.
Old May 2, 2022 | 07:53 AM
jaso's Avatar
jaso
10th Gear
I haven't used the live data feature yet.
My rear parking brake doesn't fully retract, I can't install the brake pads. If I manually push the piston back and EPB malfunctions.
