Buzzing Noise From Rx 350 fsport?
Old May 22, 2021 | 11:07 AM
Slomeee's Avatar
Slomeee
9th Gear
Default Buzzing Noise From Rx 350 fsport?
I’ve attached a clip capturing the sound I started hearing from time to time on my 2020 RX 350 f sport with only 14k miles on it.
it’s start right after I turn off the engine and last for about a minute. This is the second time I witnessed the sound.
Anyone know what it’s or know how to fix it please let me know … thanks
https://youtu.be/srWI17jEi4k
Old May 22, 2021 | 03:12 PM
eddie420's Avatar
eddie420
Wow, that is super weird and super annoying! At only 14K miles, instead of checking on the forums, go straight to the dealership to have them diagnose this for you! Show them this video clip!
Old May 23, 2021 | 02:47 AM
Slomeee's Avatar
Slomeee
9th Gear
I know, I always want to hear others experience before going to the dealership. Some dealerships will try to learn on your vehicle without giving you a clear reason for the issue, specially like my case the sound doesn’t come out every time, but I’m definitely going to show them.
Old May 23, 2021 | 09:53 AM
Badhobz's Avatar
Badhobz
It’s haunted !!!
ive never heard of anything like this before.
Old May 23, 2021 | 01:42 PM
ShrinkDoc's Avatar
ShrinkDoc
I'm the farthest thing from a car guru, and while my car often seems possessed, this sound could be (that's a huge could be) a vacuum leak from the pressure differentials somewhere in your system. It could be a small hole, or a loose connection between hoses, where there is a low vs high pressure differential. These differentials aren't always external vs internal, often it's an internal cold vs hot differential where pressure is applied to a component designed to separate the differences in temperature.
Wish I could help more, but maybe this can trigger some ideas from the many more knowledgeable folks on the forum. One final thought, this seems to be coming from where your heating cooling system is partially located. Could it be due to
low AC refrigerant gas, thereby causing pressure on the compressor.
Old May 23, 2021 | 02:36 PM
raylor4's Avatar
raylor4
This is just a guess...It sounds like audio feedback to me, but how? Bluetooth glitch? I'm very interested to hear the dealer's diagnosis. Ray A.
Old May 24, 2021 | 12:18 AM
Slomeee's Avatar
Slomeee
9th Gear
I’m convinced with this explanation, but I’ll let you all know what the dealership will do or say
by the way no electricity was on since I already opened the door, so no way this sound can come from the audio system.
Old May 24, 2021 | 06:30 PM
websurfer's Avatar
websurfer
You had the climate control system running when you recorded that video?
Old May 24, 2021 | 08:03 PM
Slomeee's Avatar
Slomeee
9th Gear
no everything was off (turned off the engine and opened the door -which shut all electricity running off-)
Old May 24, 2021 | 09:36 PM
websurfer's Avatar
websurfer
I wonder if it's the vents closing up. On my GS once I shutdown the car, it will be a minute or so then the vents closes. I can hear it. It's normal for my car.
Old Jun 13, 2021 | 01:38 AM
Slomeee's Avatar
Slomeee
9th Gear
As expected after I showed the dealer the video they got no idea where this sound may come from, and advised me if it start coming more often to come for inspection.
Up to now I only experienced this sound 3 times.
FUZCO
RX - 4th Gen (2016-2022)
52
Jan 11, 2021 07:06 AM
Bchydro604
24
Feb 16, 2018 04:54 AM
gazi001
RX - 3rd Gen (2010-2015)
18
May 7, 2012 04:53 AM
LexFather
Nov 2, 2011 08:57 PM
