Jerky acceleration while turning
Old Mar 22, 2021 | 08:20 AM
Pech's Avatar
Pech
Default Jerky acceleration while turning
2017 RX350 super low mileage. First noticed the problem while driving up a mountain pass with switchbacks on dry pavement. While turning and accelerating on hair-pin bends acceleration is jerky even on dry roads. This occurs when accelerating on flat turns as well and in either direction. Otherwise car runs perfectly with no noises and turns normally it’s only the acceleration that is impacted.
Old Mar 22, 2021 | 08:41 AM
Badhobz's Avatar
Badhobz
was it on eco mode? i found that in eco mode, sometimes the computer hunts gears trying to maximize efficiency and it causes weird acceleration surges. In normal mode its all fine.
Old Mar 22, 2021 | 03:12 PM
xxx350L's Avatar
xxx350L
What you’re experiencing is the hesitation caused by the drive by wire throttle system. Buy a Sprint Booster, and say goodbye to the “drive by wire” hesitation. BTW, I tried the Pedal Commander, and it worked as advertised, but the control unit was too bulky. Love the adjustment, and performance results of the Sprint Booster. I bought mine from Sprint Booster sales dot com. Best $299 that you’ll spend on that nice RX.
Old Mar 22, 2021 | 05:12 PM
dannnn's Avatar
dannnn
Its normal, every so often you'll also notice when your on the brakes slowing down, it'll down shift rather harshly causing you to depress the brake pedal abruptly and harder than you want for a quick second. Very annoying and people think you drive with a lead foot.
rorror45
May 5, 2022 12:02 PM
rxonfire
Suspension and Brakes
Mar 25, 2021 07:00 AM
Sugah
Performance
May 16, 2013 05:12 PM
ebruce2
Oct 1, 2008 01:20 PM
