Unknown Chime
Old Feb 12, 2021 | 03:20 PM
YVRRX350's Avatar
YVRRX350
10th Gear
Definitely not a "speed limit" warning. It is very similar to the "icy road" warning, which I am getting because of the cold weather.
I've turned off the lane departure warning, blind spot monitoring, pre-collision braking/warning....still get the chime
It even happens with the radio/ICE turned off, but there's nothing being displayed on the dash or info screen (unlike the "turn headlights ON" or "Roads may be icy").
This is driving me up the wall...
** did my thread somehow get merged with this old one ? **
Last edited by YVRRX350; Feb 12, 2021 at 03:23 PM. Reason: i think my thread got merged with an old one...
Old Feb 12, 2021 | 04:34 PM
artem123's Avatar
artem123
Yes. Moderators do that. I think it is counterproductive. People tend to reply to OP rather than to YOU who started your thread. But hey) you got your answers!
Old Feb 16, 2021 | 12:59 PM
YVRRX350's Avatar
YVRRX350
10th Gear
....but I didn't get an answer/solution to what this mystery chime is.
It still makes a tone/chime while driving
Today there was a new tone..sounded like three chimes in a row, when I lane changed. Nothing displays on the info screen, so no idea why it's making noise.
I've got as much turned off as I could (LDA, RCTA, BSM, PCA, parking assist).
Old Feb 16, 2021 | 01:52 PM
dibl's Avatar
dibl
Lexus dealers normally have a person on staff who specializes in the technology. You might be able to arrange to have the techie take a ride with you to demonstrate the issue and maybe either help reset it or identify a malfunction.
Old Apr 26, 2021 | 12:07 PM
YVRRX350's Avatar
YVRRX350
10th Gear
Just posting a follow up to my "chime" issue.
I had installed a Thinkware Q800 Pro 2-channel dash cam and it turns out that it was the Forward Collision Warning setting in the dash cam that was making the annoying chime.
While setting up/configuring the same dash cam in my Uncle's RX350, I noticed the setting and then went back into my dash cam settings and discovered that I must have mistakenly turned mine on.
The crazy thing is the warning chime sounds almost exactly like the warning tone that the car produces for things like "icy road warning".
Great dash cam...easy to install and configure.
Red light/speed camera warnings are helpful. Only issue with install is accessing the horribly located fuse "box".
Next up is installing one into my Evora GT....
Old Apr 27, 2021 | 05:56 AM
bamalam's Avatar
bamalam
Thanks for posting the outcome. It's crazy how difficult it is to track down the source of sounds in a car. You'd think your situation would be obvious, yet it wasn't. Glad you figured it out.
Where did you mount the Q800 in your RX? (On the frit on right or left side of the mirror housing, on the housing itself, etc?) Is the lens off-center and, if so, by how much? I'm considering either the Q800 or the Viofo A139. Both have similar form factors, although one has a left-hand lens and the the other right handed. My hesitation is if I mount it on the frit, the lens will be 8"-9" (20-23cm) off center, and I'm wondering if that is impractical.
Old May 6, 2021 | 10:48 AM
YVRRX350's Avatar
YVRRX350
10th Gear
Mounted right behind the rear view mirror, offset a little so the cables can run directly down.
Hardest part was getting under the dash to make the +12v/accessory connection at the fuse box (what a horrible location!)
Second hardest was getting the rear cable to go through the rubber grommet at the hatch. Coil extra length of rear cable up and hide in headliner.
Thinkware Q800 Pro - Front
Thinkware Q800 Pro - Rear
Old May 6, 2021 | 07:45 PM
bamalam's Avatar
bamalam
Very good. Thanks for the pics.
Old May 7, 2021 | 04:17 AM
dibl's Avatar
dibl
It's not a great photo, but it shows how I installed the front camera. It is a little too close to the top of the windshield, which makes it difficult to remove the SDHC card, so if I were doing it over, I would lower the camera about a quarter inch. But it's a very neat installation, with all the wiring tucked under the trim.
Old May 7, 2021 | 09:30 AM
bamalam's Avatar
bamalam
Thanks, @dibl . Good thought about the placement; I'll be sure to remember to account for both camera and SD card removal. I'm thinking about placing mine in the same position, but on the driver's side, so most of the camera is beneath the frit. I'm probably overly concerned about the camera being visible from the outside.
Do I remember reading that you ran the rear camera cable along the bottom trim, and not the headliner? If so, did you have any challenges getting the cable up to the headliner in the rear?
Old May 7, 2021 | 09:46 AM
dibl's Avatar
dibl
Yes, with offline pointers from another forum member, I ran the data cable through the biggest grommet on the rear hatch, angled it to go behind the airbag over the rear passenger-side seat to the C pillar, down the pillar underneath the plastic, and then under the kick plate or sill plate -- whatever it is. Under the B pillar plastic, under the the front passenger sill plate, and up under the A pillar plastic. Although I worried about the cable length when I first saw it, there was probably 2 extra feet that I had to coil behind the A pillar airbag. The trim over A pillar airbags were the toughest part of the job -- they have a hard plastic restraint link to keep them from becoming missiles when the airbag blows. That link has to be twisted, with needle nose or similar pliars, and held 90 degrees from its normal orientation while the trim piece is removed. You need to run all cables UNDER airbags. Then the plastic holder has to be twisted again to replace the trim piece. Also, be careful with the headliner in the rear -- it seems very fragile and I was warned not to pull it down except for the very edge where you need to insert your tool to pull the data cable. I used a long stiff wire, ran it from behind the rear passenger side door under the headliner to the top rear of the roof, and then taped the data cable end to the wire, and pulled it through.
That might be a superior result, if you can do it. I was intimidated by the prospect of getting my data cable neatly past the rearview mirror assembly.
Old May 7, 2021 | 10:06 AM
bamalam's Avatar
bamalam
Great description; thank you! Now all I have to do is buy the darn thing....
Old Jan 30, 2022 | 12:51 PM
Chrissx101's Avatar
Chrissx101
2nd gear
Just bought a new 2022 rx 350 and the bell chimes every time we pass a speed limit sign then it shows up on the notification screen by the speed odometer. I think you can turn off the chime. Hope that’s all it is for you.
Hoovey689
May 7, 2021 09:04 AM
FastFord
Wheels, Tires & Brakes Forum
Nov 18, 2016 10:46 PM
shinbrianj
Dec 15, 2008 02:59 PM
hakes
Apr 23, 2007 05:09 AM
DeniskaGS4
May 25, 2001 07:14 AM
