Difficulty removing mechanical key from remote
Old Aug 29, 2020 | 07:43 PM
john91945's Avatar
john91945
Default Difficulty removing mechanical key from remote
Just got a new 2020 RX350. Learning the system and am having trouble removing the mechanical key from the electronic remote farb. Tried everything - pressed in the small lever on the remote but still can't remove the mechanical key. Any suggestions?
Old Aug 30, 2020 | 02:19 AM
rxtimes2's Avatar
rxtimes2
Only thing I can think of — press the lever, and first push the key in before trying to pull it out.
Old Aug 30, 2020 | 07:20 AM
Quantum501's Avatar
Quantum501
there is a button at the far end of the fob on the side that you must depress first....press the far tip of that towards the bottom of the fob....should pop right out
If you tried that and it is not working then there must be a mechanical break somewhere. Mine slides right out.
Picture below to show pushing at bottom tip to get the release.
try your other fob. The likelihood of both being broken is probably 0. Good luck
Old Aug 30, 2020 | 07:24 AM
Quantum501's Avatar
Quantum501
Old Aug 31, 2020 | 04:20 PM
bamalam's Avatar
bamalam
It case it is not obvious, the mechanical key is on the same side as the button, as shown in the photo. I happen to know someone that spent 5 minutes trying to pull the brushed aluminum part from the fob....
Old Sep 1, 2020 | 02:29 PM
john91945's Avatar
john91945
Update: Yes I did try pushing that small button in. Key still won't release. Same issue with my other farb - the key won't release. Then a strange thing happened the other day - I was just playing around with the farb and pushing the button in, and low and behold the mechanical key released. It worked fine- tried it several times - it worked. But then next day, I tried again and same issue - the key would not release. I give up - the key must be haunted ! lol!!. Going back to dealer for help.
Old Sep 1, 2020 | 02:39 PM
dibl's Avatar
dibl
LOL. Hopefully you won't ever need it!
Old Sep 2, 2020 | 12:15 PM
Quantum501's Avatar
Quantum501
very strange indeed....let us know what you find out. Strange to have both be not functioning!
Dionhgreen
Sep 21, 2019 08:12 AM
Arpadf189
Hybrid Technology
Aug 1, 2019 10:37 AM
Pogigreg
Sep 12, 2008 07:29 PM
dsaeed
RX - 1st Gen (1999-2003)
Dec 12, 2003 02:59 AM
