Rotors OEM or another brand?
Old 12-26-19 | 06:06 PM
rusn007's Avatar
rusn007
Default Rotors OEM or another brand?
My 2016 has 60K on the clock and when I brake I'm feeling vibration.
Changed my brakes at 50K miles and rotors were ok. So now I need to decide to resurface rotors or buy new ones.
For those who replaced rotors - did you go with OEM or another brand? If other brand - who did you go with?
Thanks
Old 12-26-19 | 06:37 PM
richard203's Avatar
richard203
if ur last time brake job they resurfaced ii would change the rotor out this time. did you try centric, stoptech, brembo those are the brand i would use
Old 12-27-19 | 09:08 AM
RiceBanana's Avatar
RiceBanana
I normally use Centric or Bosch based on the price and car I'm working on. Never had issues with these 2 brands but you can always go with OEM if the price is similar.
Old 12-27-19 | 06:03 PM
rusn007's Avatar
rusn007
Last brake job (new pads) they did not resurface the rotors - said they were fine.
Will look into stoptech and brembo.
Old 12-28-19 | 03:06 AM
richard203's Avatar
richard203
even if they say its fine and no need to resurface u still using the same rotor so i would just replace the rotor. normally after i used the rotor two times i just change out the rotor on my 3rd brake job.
Old 06-09-21 | 09:32 AM
artem123's Avatar
artem123
Default Front rotors
Hello Lexy Rexy drivers.
Long story short after 11k miles my front rotors are out of round which results in shimmy when break. It is very pronounced on highway speeds, and even in slow traffic, i could clearly feel it. The dealer tells me that the only roads they can road test is those around the dealership and posted speed limit is 35. They do not want me in the car during the test due to everyone knows what, although the same dealer had no problem have a test drive with me when I purchased the car last august. Anyways, i want to replace rotors, but i don't want originals, i want better. What are the good brands out there? With my German fleet, i always used originals or 2 exceptional brands which are Brembo and Zimmerman's. What are good brands for rx?
Thank you.
Old 06-10-21 | 08:52 AM
PhxBill's Avatar
PhxBill
One thing I have found with my Camry: the lug nuts absolutely must be torqued evenly to spec (sorry I don’t remember the torque value) or there will be shimmy upon high-speed braking. I too was convinced my rotors were warped because sometimes the shimmy was quite noticeable but after rotating the tires myself and torquing the lug nuts properly, all was well.
artem123 (06-10-21)
Old 06-10-21 | 01:52 PM
JeffKeryk's Avatar
JeffKeryk
There is a relatively new pad and rotor, Raybestos Element 3. Excellent value for excellent brake components.
The coated rotors are about $42 on RockAuto. The pads are $33 and are a new, hybrid compound. Shipping is kinda high...
What pad did oyu use? The factory pad is excellent, if you wanna spend a little more.
Good luck.
Old 06-11-21 | 05:23 AM
artem123's Avatar
artem123
Good luck.
Hello!
If you ask me i did not change anything yet, all the rotors and brake pads are the original. Car just hit 11.5k on the clock. Dealer fails to acknowledge the fact that it shaking when I break because speed limit is 35 around dealerships and they cannot go above speed limit during test drive. Frankly I don’t wanna fight with them anymore I would much rather change the rotors and pads
Old 06-11-21 | 05:38 AM
offroad200's Avatar
offroad200
Make sure you bed the brakes properly.
Old 06-11-21 | 05:52 AM
artem123's Avatar
artem123
Yes, however my car was breaking fine until 10k. Then, suddenly it developed a shimmy. I NEVER use automatic car wash where hot rotors are sprayed with cold water. I ALWAYS enjoy washing my cars by hand)
Old 06-11-21 | 09:21 AM
ravenuer's Avatar
ravenuer
For a car to just "suddenly" develop a brake shimmy, something went wrong. Were any of the wheels removed and not torqued properly?
Old 06-11-21 | 09:53 AM
artem123's Avatar
artem123
Actually when you say it now…
Car was at the dealer for 10,000 miles service…
Hmmm
Old 06-11-21 | 10:07 AM
PhxBill's Avatar
PhxBill
Tires were rotated and possibly not torqued down evenly. If you have access to a click-type torque wrench (the cheaper beam type with a pointer needle isn’t accurate enough), this is easy for you to fix. Merely jack the car up, loosen the lug nuts, then re-torque them. Go up in value progressively, over two or three steps, until you reach the right value which is 76 ft-lbs according to the manual. Be sure to torque them in a “star” or criss-cross pattern, don’t just go around from one lug nut to the next.
ravenuer (06-11-21)
Old 06-11-21 | 10:21 AM
artem123's Avatar
artem123
I will get a torque wrench and report.
