2018 Rx350 Bluetooth disconnecting
Old Oct 24, 2019 | 03:21 PM
gschabes's Avatar
gschabes
Default 2018 Rx350 Bluetooth disconnecting
2018 RX350: Bluetooth has suddenly begun to spontaneously disconnect (Android or IPhone with up-to-date software) and not reconnecting. In trying to remove a device and add it again, the program slows and never connects. The devices may momentarily recognize the vehicle on start-up and are then dropped with a Lexus device no longer found on the phones.
Any ideas aside from going to the dealer?
Thanks.
Old Oct 24, 2019 | 05:25 PM
mikemu30's Avatar
mikemu30
Thanks.
Hard reboot of the info system may be worth a try. Then try to pair again.
Old Oct 25, 2019 | 03:05 AM
gschabes's Avatar
gschabes
How to hard reboot? Is there a sequence I can perform?
Old Oct 25, 2019 | 05:14 AM
JSracer's Avatar
JSracer
press and hold the volume **** for the radio. it will reboot.
Old Oct 25, 2019 | 05:33 AM
gschabes's Avatar
gschabes
Thanks. Will try. TBC
Old Oct 25, 2019 | 12:17 PM
kmiller882's Avatar
kmiller882
Thanks.
You may also try completely "Forgetting" the device on the phone(s), delete the phone(s) from the vehicle's bluetooth, and start the entire pairing process over from the beginning.
Old Oct 25, 2019 | 12:24 PM
gschabes's Avatar
gschabes
When trying to delete a device, and add it back, the program stalls and never completes the process. The phone would not see the car's Bluetooth anyway. My daughter just said that the system just spontaneously rebooted with only temporary improvement in connectivity but this was not the hard boot that was suggested and has yet to be tried.
Thanks.
Old Oct 25, 2019 | 12:26 PM
kmiller882's Avatar
kmiller882
Thanks.
You might check lexus drivers to see if there's an update for your system. Sometimes there are updates you can download to a USB and update your system. All else fails, go to your dealer. Something is definitely wrong there.
Old Oct 30, 2019 | 08:16 AM
gschabes's Avatar
gschabes
Update. The reboot, while still not recognizing a previously paired device, allowed me to delete and re-pair my phone successfully. Hopefully, it will last.
Thanks to all who responded!
Old Nov 13, 2019 | 07:03 AM
MDBYERLYS's Avatar
MDBYERLYS
Default RX350 Bluetooth Disconnection issues
Thanks.
I am experiencing the same issues. Dealer stated - two Iphones connected may be the source of the problem, Recent IOS update may be the source of the problem and suggested I make an appointment with the Navigation Specialist.
I will try the hard reset Thank you
Old Nov 13, 2019 | 07:21 AM
gschabes's Avatar
gschabes
Then delete and re-pair all
Eagleguy
May 4, 2017 06:42 AM
Mikekm
Jul 25, 2014 04:39 PM
Xpcgamer
Sep 26, 2013 02:42 PM
JoeZ34
Aug 4, 2011 11:36 AM
JoeMonty
RX - 3rd Gen (2010-2015)
Mar 13, 2010 03:05 PM
