iPhone USB Audio Playback
Old Oct 6, 2017 | 09:08 AM
FSportWaxy's Avatar
FSportWaxy
Default iPhone USB Audio Playback
Curious if anyone has a solution for the "Ipod Not Connected" on-screen message when plugging my iPhone 6 into the USB port (2017 Lexus RX350 F). I can play audio when selecting songs on Spotify from my phone, but I thought there would be hands free capability to cycle through songs....similar to bluetooth?
Old Oct 6, 2017 | 11:17 AM
mcomer's Avatar
mcomer
Media on an active phone works best through BT. When you paired the iPhone VI it also connected the BT.
Press the hard key "Media" or select source with remote controller. Be sure that the device volume is 1/2 or higher.
Plug the USB cord into a 12v dc adapter and use one of the four (4) power ports, they supply much more than the
500 milliamp (.5 amp) that the USB jack can. Steering wheel controls and display of songs will be connected.
Trouble can arise when you hardwire to the USB jack including failure to segue from phone back to media after a call.
Use the USB cable to connect any non-phone device iPod or flashdrive. On the RX you can put an iPod in the
small covered cubby and loop a .5 meter ("14) lighting cord to the USB. Leave it on forever and it will trickle
charge (when the RX is on), enjoy great bandwidth and best of all, verbal command function...press Off Hook
and say "Play Artist Eric Clapton!)
Old Oct 6, 2017 | 01:35 PM
FSportWaxy's Avatar
FSportWaxy
Thanks for that info. I find a noticeable difference in sound quality between bluetooth vs. USB or AUX....probably since audio is being compressed. I don't mind running a station or playlist from my iPhone with the USB cable plugged in, I just wish I had hands free capability (similar to Pandora with the built in enform app).
People still have ipods these days? LOL
Old Oct 6, 2017 | 10:52 PM
lexnewbi's Avatar
lexnewbi
I use an iPhone 6 everyday with USB on a 2017 RX 450h. Sometimes when I connect my iPhone wile the Navi is booting the iPhone is not recognized. I have to disconnect the cable and reconnect again to get it to play. The controls on the steering and radio will pause, play, forward, and rewind the songs.
I also find the audio quality is better with USB than Bluetooth. Bluetooth uses a compression scheme to transmit the audio that adds some distortion.
Old Oct 6, 2017 | 10:59 PM
lexnewbi's Avatar
lexnewbi
Originally Posted by mcomer
Plug the USB cord into a 12v dc adapter and use one of the four (4) power ports, they supply much more than the 500 milliamp (.5 amp) that the USB jack can. Steering wheel controls and display of songs will be connected.
I measured the USB charge power on my 2017 RX450h and it is 1A on each port.
I have ace no problems getting a phone cal, the phone pauses the music,l answering with hands free Bluetooth or my Bluetooth headset and then continuing to play music once the call hangs up.
My annoying bit bit is that every time I connect the iPhone with USB and select the phone on the radio, it starts playing the first song. However, if I plug in the iPhone before starting the car, it will continue playing the last thing it played, a podcast, or audiobook that is not in the iTunes app.
Old Oct 9, 2017 | 12:50 PM
ericsan13's Avatar
ericsan13
I use iPhone 7 Plus everyday with USB on 2016 RX 450h and never have any problems connecting. Are you using a high quality MFi lightning cable? Cheap cables fail all the time. Even MFi cables fail.
Old Oct 12, 2017 | 10:07 AM
Hubs's Avatar
Hubs
Every now and then when I plug in my iphone and my ipod, the system jumps between the two devices randomly.
Old Oct 12, 2017 | 02:04 PM
ggebhardt's Avatar
ggebhardt
It would be nice if the RX would play what was on my phone wirelessly.
Old Jul 28, 2019 | 04:49 AM
aubergine's Avatar
aubergine
hi does this unit require the stereo to be on cd if you want bluetooth phone calling /answering or does it switch automatiaclly .
Old Jul 28, 2019 | 07:23 AM
mspearl95's Avatar
mspearl95
bluetooth works no matter what the stereo is set to.
bmexxxzee
NX - 1st Gen (2015-2021)
Jan 2, 2019 04:08 PM
donkiboy
Dec 28, 2018 07:44 AM
beer88
RX - 3rd Gen (2010-2015)
Aug 18, 2014 08:34 AM
IS3Fguy
May 9, 2014 09:35 AM
dano9258
IS F (2008-2014)
Aug 12, 2012 08:28 AM
