Question: Has anyone done these upgrades or attempted these things?
Hi guys, new to the forum. I tried to search a few things and haven't come up with the answers I was looking for so I figured I'd ask you guys directly.
1. Has anyone done a new battery install? Every car that I have owned, I changed to an optima yellow top right from the get go. I need to find the right sized battery and cant seem to find reliable information on the size or model number that is needed for the 4th gen RX.
2. Also has anyone attempted the BIG 3 upgrade (changing the grounding cables from battery-chassis, distributor block-chassis, and alternator to chassis [as well as running a new power wire from the alternator to the battery]). If so is there an "how-to" guide on how to do so? If anyone has had experience with this, how difficult was it to access all the areas needed for the BIG 3.
3. Without the Ensuite app, has anyone successfully remote started the car from the key fob? I attempted the "press lock button switch, press third time and hold for 3 seconds." This does nothing. Maybe the mode needs to be enabled on the car somehow?
4. Has anyone successfully rolled down their windows using only the key fob?
I have a few other things I wanted to ask but figured this is a good start. Thanks for any feedback and excuse my n00bness. I promise to post pics of anything that I have done to the car as time goes on. Thanks!
EDIT BTW, figured I'd ask one more question. I have the navi package and I noticed that it may have DVD playback. Has anyone hacked the screen to allow an hdmi connection (or something similiar) in order to display off of a phone or computer? Thanks for any thoughts.
3 and 4 are not upgrades it is features that are working as designed no issues on my end.
Would you explain why you feel there is a need for 1 and 2. What is the purpose and gains? I am puzzled. Thank you.
So for 1 and 2: when you upgrade the battery, electronics on the car work better, headlights shine brighter, even throttle response is improved. By doing the big 3 upgrade you will notice your alternator working better with less stress and most electronic in the car working more efficiently. If you were to test the output from the accessories before and after there would be a noticeable difference. For example, the audio will sound better, hit better, and even be louder because you are giving it more "Clean power." Essentially the Big 3 upgrade re-grounds your whole car with 0 gauge wiring rather than the standard 4 gauge.
Thanks dwayneir! Is this also true for the remote start feature? I swear to god I've tried every variation of *press lock 3 times, hold the third time* that I could think of.
WOW this is BS! I was reading about the 2016 and read that people who do not have an active subscription can still remote start their car with the key fob. When did this change? Is there anyway around it? Possibly signing up for enform and then cancelling subscription a month later. Maybe the remote start will remain on the key fob?
2. Also has anyone attempted the BIG 3 upgrade (changing the grounding cables from battery-chassis, distributor block-chassis, and alternator to chassis). If so is there an "how-to" guide on how to do so? If anyone has had experience with this, how difficult was it to access all the areas needed for the BIG 3.
Also I have not heard of anyone on the forums who has attempted this.
A capacitor is just a crutch and bandaid on the system. It doesn't really benefit anything and actually makes your alternator work harder because with each discharge (aka bass hit) your battery will be charging and also the capacitor will need to be charged. It ultimately will not be beneficial in the long run. I tried the capacitors, which work for a bit of time, but I am looking to "ground" the whole car. Hopefully that sheds some light on my thought process.
Hey Ericsan, thanks for the warm welcome! I may plan to do add a full aftermarket system in the future. I have a few other mods that I wanted to address first. Being that I have the premium sound system any upgrades will need to be with a special adapter. The more potential components I add, I will need to ground them and potentially will introduce audible noise loops into the system. So that will have to wait for now.
There are two Lexus and infinite aftermarket answers to the Remote Start question:
As ggebhardt noted, you must have a current and valid subscription to Lexus Safety Connect
to use the phone app and key fob for Vehicle Finder, Guest Driver monitoring, Stolen Vehicle
recovery, Accident Emergency notification and Remote Start. $250/year I do not need or pay
for the Navigation Assist option that raises the subscription to $350/year...use the free Lexus
Enform App Suite instead.
You can have a dealer install either the Remote Engine Start (RES) fob only or RES+ which add the
phone app. RES is <$500 and is the fob only <'80 range with no subscription or RES+ for <$1000 which
add a phone app and as with all phone enabled systems has an ongoing subscription.
Aftermarket add-ons vary widely in cost and range but generally are a better value if all you want is
the remote start. If you want to follow the antics of Valet Parkers and/or teen age drivers go with the
Lexus app. (Remember that an enabled spouse's phone can track you too!)
I will look into that today AND I wanted to add this particular addition to the car Navi. It enables toggling and modification of the navi when the car is in motion
http://www.vaistech.com/product/ulm-81/
Option 1: Pay $24.99 per month (a.k.a. 250/year) - proxy remote start with app
Option 2: Pay $1000 up front and follow up with $65/year for RES+ - proxy remote start with app
Option 3, Pay $500 for key fob remote start only with RES - This pays for itself in 2 years
Unfortunately, after market is out of the question because a good one will cost $$$ and still add a new remote to the keychain.
Originally Posted by ericsan13
Cool, I am looking forward to seeing how you beef up the electrical system and how much bumps you are going to put in your ride.
UPDATE: I activated the EnformApp and the remote start began working both in App and on the key FOB. GO FIGURE! I did a little more research and found this bypass module for the remote start. I just realized that since Lexus has a programmable remote start which is disabled by LEXUS without the active enform subscription this MEANS that there is a bypass module somewhere. This is what I found and I think it might just be the solution instead of the RES factory install. Any thoughts?
*Link Below*
http://fortin.ca/en/products/evo-series/evo-all/
*Link Below*
I am sorry but an Otima battery and heaver cables would not yield the advantages you claim.
I just do not see better sound or engine performance unless your original battery and cables were bad.
