Brake pad replacement
Old Mar 27, 2023 | 05:21 PM
  #166
Quantum501's Avatar
Quantum501
Originally Posted by jcg0324
Some experts highly recommend Japanese made Akebono brake pads. For a 2017 RX 350 front and rear pads will run about $125.00 on Amazon. Part numbers are ACT1324A (front) and ACT1879 (rear). For more information check out this site: https://akebonobrakes.com/
I have used these as well and they are very good. Scotty loves them!
Old Mar 28, 2023 | 12:14 PM
  #167
k2imperial's Avatar
k2imperial
10th Gear
Following are the brake rotor and pads part numbers for RX350 Base.
Canada built
Front Rotor : 43512-0E050
Rear Rotor : 42431-0E060
Front Pads : 04465-02500
Rear Pads : 04466-0E060
Japan built
Front Rotor : 43512-48130
Rear Rotor : 42431-48090
Front Pads : 04465-48210
Rear Pads : 04466-48160
What are the after market supplier part numbers for the Japan built?
Old Mar 28, 2023 | 12:46 PM
  #168
FlopTop04's Avatar
FlopTop04
To answer your question, see my Post #80 in this thread. I included the info I found when I changed brakes on my Japan built 2018 RX350.
Old Mar 30, 2023 | 11:09 AM
  #169
k2imperial's Avatar
k2imperial
10th Gear
Thank you for the info.
Please post the front pads & rotor parts number if you know.
Old Mar 30, 2023 | 12:34 PM
  #170
FlopTop04's Avatar
FlopTop04
This is the info from my rear brake job on my Japan built 2018 RX350. The prices
shown are from June of 2021 and out of date. The front brake parts are the same
for Japan or Canadian built models.
I spoke with a dealer parts counter rep and got the actual part numbers needed
for the brake job. Here is the list of official Lexus parts :
2018 RX350 with AWD and "J" as the first letter of VIN
Rear Pads 04466-48160 $71.06
Rear Pad Shims 04946-48130 $40.69
Rear Pad H/W Kit 04948-48110 $26.23
Rear Rotor 4 1431-48090 $120.00
Crossing these numbers over to aftermarket parts can be difficult. I used
Rock Auto and entered the Lexus part numbers and came up with the following :
Raybestos Rotor 982051FZN $36.89
Raybestos Pads w/HW kit EHT1879H $17.43
Old Mar 30, 2023 | 01:21 PM
  #171
KevMaster's Avatar
KevMaster
One thing that I've found that helps on the front brakes, is using a more aggressive pad. I'm using the EBC Yellowstuff and I'm way happier with it than the OEM pads.
Old Mar 30, 2023 | 07:14 PM
  #172
Hsultan's Avatar
Hsultan
I can’t thank you all enough for the really helpful replies. Going so far as including the part numbers was above and beyond. Thank you!
Old Apr 12, 2023 | 10:26 AM
  #173
NFaridi's Avatar
NFaridi
Does the 4th gen RX's come with a brake pad sensor wire front and/or rear?
Old Apr 12, 2023 | 11:06 AM
  #174
arrowroot's Avatar
arrowroot
I was told that both the front pads and rear pads have a piece of metal that will squeal if the pad thickness gets low enough. Not sure how true this is, as I haven’t checked myself.
Old Apr 12, 2023 | 11:18 AM
  #175
toyotaman7's Avatar
toyotaman7
No sensor. Just a squeaky thingy (if that's a technical term) 😀
Old Apr 12, 2023 | 12:31 PM
  #176
NFaridi's Avatar
NFaridi
thank you guys! the usual metal pin that squeals. great $ saved! lol
Old Apr 16, 2023 | 05:01 AM
  #177
DweN's Avatar
DweN
Why not just put the car on N and turn the car off and do the break pad change? So it will not activate the E-Break.
I didn't try yet but logically it should work. I still haven't break pad changed first time so it will be good to know.
Old Apr 16, 2023 | 05:32 AM
  #178
toyotaman7's Avatar
toyotaman7
By default when e brakes are not activated the caliper is extended to just before touch. You can not do brake job without activation of brake maintenance mode or some other method to retract the e brake motors.
Trying to disassemble them will ruin the system.
Old Apr 17, 2023 | 06:27 AM
  #179
DweN's Avatar
DweN
I thought it retracts all the way always when it deactivates. So my assumption is wrong. Anyway I will check when it is time to replace the pads.
Thanks for the info.
Old Apr 17, 2023 | 06:34 AM
  #180
DweN's Avatar
DweN
OK So, I found this video so it does not need the any diagnostics tool. You just remove the one side connector for parking break and it will completely retract the other connected side.
