Mark Levinson vs Standard Audio System
Old Aug 27, 2017 | 12:44 PM
  #106
mikemu30's Avatar
mikemu30
Originally Posted by ggebhardt
I found adjusting my ML radios balance to the rear and then increasing the volume works best for me.
I initially did just that. Today I also turned off the surround as someone had suggested and that makes a big difference.
Old Aug 28, 2017 | 08:33 PM
  #107
vital350's Avatar
vital350
Thanx for replies guys. My ASL is on, surround off and it still sounds like crap in the back. Even if I adjust balance a bit to the back it still nowhere near what I'd expect from "LEXUS PREMIUM ..." or any other car system for that matter.
It just really sounds very weak in rear. At this point I just want to meet someone with RX and listen how it sounds in their car, I'm literally thinking there's something wrong with my rear speakers, that's the only way I can make sense out of that (lack of) sound.
Old Aug 29, 2017 | 12:16 AM
  #108
Nail34's Avatar
Nail34
What does sound like when you move the balance 100% to the rear speakers and leave all else in neutral??
Old Aug 29, 2017 | 07:36 AM
  #109
vital350's Avatar
vital350
In this case rear speakers work but defiantly not loud enough comparing to fronts when balance is in the middle. And most importantly there's zero "impact" or "feel" if you know what I mean. Speakers do work (produce sound) but as I mentioned before it's like they are not hooked up to an amplifier while fronts are. Reminded me of the days I used to play around with aftermarket speakers on older cars when you have rocking system all around but decide to not touch stock rear speakers so you can hear the difference between "awesome aftermarket set up and crappy oem" right away
Old Aug 29, 2017 | 09:07 AM
  #110
kg11's Avatar
kg11
My ML sound does seem to be louder at the front. This is something that should be fairly easy to measure and I'll make the attempt.
As for quality, it sounds kind of ordinary compared to the ultrasonic highs, earthquake-like lows, and thunderclap dynamic range of some systems, but I find the vocals are very clear and it's easy to listen to for long periods of time. Older recordings often seem monophonic, but newer ones can be awesome.
Old Aug 29, 2017 | 09:09 AM
  #111
Nail34's Avatar
Nail34
My balance is 2 clicks to the rear like others suggested and surround sound sucks. The front speakers should be louder, clearer, etc however when I turn off the front speakers the sound is not as dynamic but it still is a pleasant sound and I can turn it up to the point where it is way too loud.
However that's the ML system, there could be a much different result using the standard system therefore it would be more beneficial to you to have someone using the standard system to comment.
Old Aug 29, 2017 | 09:19 AM
  #112
Htony's Avatar
Htony
Originally Posted by s4iscool
I love it. It's got sound imaging that most aren't used to because it's more realistic with the front center balance. Plenty of bass punch too with quality sources of music. Xm still sounds terrible
Sound quality is better than standard unit over all. XM radio issue is because it is based on satellite link.
Any audio system has to be set up properly initially like any other system like home stereo or home theater.
Old Aug 31, 2017 | 12:36 PM
  #113
kg11's Avatar
kg11
The numbers are in: If the reference level is the passenger front at 0 dBA, the right rear is -4.2 dBA. Roughly less than half the sound power, but due to ear's own level adjust, just noticeably less.
ML System.
Method:
1. Create a WMA file a 30 second frequency sweep logarithmically 20Hz to 20kHz place on USB stick.
2. Set sound controls to surround ON, volume balance/fader at center, flat frequency (default).
3. Record sound with Zoom H4N Pro audio recorder at stereo 44kHz sample rate and microphone set to 120degrees.
4. Analyze recording with Audacity and Wave Stats plug in.
Attach screen captures of Audacity. Not sure they will make it to post.
Attached Thumbnails Mark Levinson vs Standard Audio System-frontpass.png   Mark Levinson vs Standard Audio System-rightrear.png
Old Aug 31, 2017 | 12:52 PM
  #114
mikemu30's Avatar
mikemu30
ML System.
Method:
So is it better to have surround ON or OFF for the rear sound?
Old Aug 31, 2017 | 04:11 PM
  #115
Bearcat's Avatar
Bearcat
All I can say is that I love my RX but the ML system is absolutely horrible. Yes, the regular system is even worse, but I expected so much more with the ML. Just purchased an 18 XC90 for my wife with the Bowers&Wilkins and have to say, no comparison, they know how to make a truly awesome system in an SUV.
Old Sep 1, 2017 | 05:13 AM
  #116
Mike728's Avatar
Mike728
Definitely OFF for a comparison like this.
Old Sep 1, 2017 | 07:26 AM
  #117
Htony's Avatar
Htony
It depends whether the source material is encoded as 5.1 or 7.1 or 9.1 or 11.1 format.
If not, system will emulates surround mode. You folks should have home theater?
Ought to understand about Dolby, THX, Natural DTS, Atmos, stuff like that. If you play 2 channel stereo
material it won't produce real surround sound like sitting in a cinema. AVS forum is
a good place to learn about this things. If one wants to set up the system,pick a
good reference source material(usually Blue Ray disc) like good sound track
from a famous movie, etc.
Old Sep 1, 2017 | 08:02 AM
  #118
Mike728's Avatar
Mike728
Exactly, except the ML only decodes 5.1ch DD. The matrix "surround" mode setting is just a gimmick and actually degrades the audio. If you play a DD 5.1 DVD, it will play in surround mode with the setting disabled. I assume the test above was performed with a 2ch source. In any case, it will be much louder in the front, than the back by design.
Old Sep 1, 2017 | 09:14 AM
  #119
kg11's Avatar
kg11
Okay, same test with DSP off (maybe recorder positioned slightly different). The A-weighted sound in the back is -3.3dBA from the front. Just slightly louder.
Comments are correct. It's not the most scientific test, though reasonably repeatable if someone should do this with a premium system instead of ML. Possibly, the sound is biased towards the front to allow easier conversation in the back.
For reference, here are the new Audacity trace overlaid over the old.
Attached Thumbnails Mark Levinson vs Standard Audio System-frontvsdsp.png   Mark Levinson vs Standard Audio System-rearvsdsp.png
Old Sep 1, 2017 | 09:55 AM
  #120
mikemu30's Avatar
mikemu30
You're all over-analyzing the sound in a car - it's not a home theatre. But do what works best for you.
