Mark Levinson vs Standard Audio System
Old Jul 11, 2018 | 05:35 AM
  #256
Htony's Avatar
Htony
Originally Posted by Usual
I know the input source has been mentioned several times in this thread, but I thought I would share my own experience.
I bought an ipod touch to fit in the center console holder and yesterday I set up the same song playing from the ipod and from my phone through bluetooth. Switching back and forth I found there is essentially no bass coming from the bluetooth input. The ipod sounds great. I tried this for several songs (I have the same playlist downloaded on both the ipod and my phone) and also switching the surround sound and auto level on and off. I have the standard audio system.
I think BT does not have wide frequency response. Good bass needs a frequency range as low as 60Hz. Most woofer crossover frequency is like 100Hz. If my home theater woofer is fed 60Hz signal it is
house shaking but not much audible to my old ears, LOL! I am a low brass player so know a thing or two about bass level sounds. Good amps have LFE output feeding woofer. Bass does not have good
stereo image. So most of time a system has one woofer. I always keep audio set up reference CD and video set up reference DVD to set up a system properly. Good stereo is enough to enjoy music.
Surround sounds are for simulating theater.
Old Jul 11, 2018 | 06:38 AM
  #257
GSFRX350's Avatar
GSFRX350
Agree, same goes for using a USB drive although not to the same extent. I have an old iPhone that I've loaded my music onto connected via USB so the iPhone "plays" the music and the car system just amplifies it. Using the USB drive the car system is "playing" the music and amplifying but the car system does not decode as well as the iPhone. Bluetooth is just crap basically, struggles with phone calls sometimes so don't expect much with music.
Old Jul 11, 2018 | 08:09 AM
  #258
Cocal's Avatar
Cocal
Originally Posted by shimps1
Do you have have an RX350, or a 350L?
2017 RX 350 Luxury pkg, but packages may differ between Canada & US
Old Jul 11, 2018 | 06:32 PM
  #259
richard203's Avatar
richard203
im using Bluetooth for song, I tried listening to radio the bass is much better and louder than my music when playing Bluetooth.
Old Jul 11, 2018 | 08:59 PM
  #260
lexnewbi's Avatar
lexnewbi
Yes, Bluetooth music is highly compressed and has little bass and high frequencies. Use USB connections for greater fidelity.
Old Jul 12, 2018 | 11:51 AM
  #261
sejijohn's Avatar
sejijohn
Hi, recently I brought RX350L AWD with premium package. The 12 speaker system sounds just fine but not that great... unfortunately ML speakers was not available even as an option in the premium package.
is there any way I can upgrade just my speakers to a better sounding one? I did an online search for speakers but found this wonderful forum instead. If this is a repeat question, please forgive me as I am new to this forum. Thank you.
Old Jul 12, 2018 | 12:02 PM
  #262
gadgetman1's Avatar
gadgetman1
Sure, you can always upgrade your speakers, but you will have lots of homework to do. The ML system has more speakers & a more powerful amplifier than the premium system & you will need to find out the correct ohms of each of the ML speakers. You will need to meet that ohm number or have a lower number, which is very expensive. I would suggest finding a wrecked RX with the ML system & use those speakers and/or amp. I’m not sure if the head unit is comparable either - lots of homework! Let us know what you find out.
Old Jul 13, 2018 | 09:41 AM
  #263
xcinlb's Avatar
xcinlb
I would suggest, going to automobile audio shop and talk to them about wanting better sound, they may suggest speakers, but they may also suggest adding an amp. See what they say.
Old Jul 13, 2018 | 09:59 AM
  #264
sejijohn's Avatar
sejijohn
Thanks xcinlb. Any idea if this can void the warranty?
Old Jul 22, 2018 | 10:02 PM
  #265
richard203's Avatar
richard203
I was wondering when I listen to radio the Bluetooth still connect to my phone? is there a way to disable that?
Old Jul 23, 2018 | 04:54 AM
  #266
Mike728's Avatar
Mike728
Not sure why you would want to, but you could just turn off Bluetooth on your phone.
Old Jul 23, 2018 | 06:42 AM
  #267
ravenuer's Avatar
ravenuer
I thought that was the point of having Bluetooth, no?
Old Jul 24, 2018 | 08:48 AM
  #268
dchan865's Avatar
dchan865
My rx300 standard audio system has a subwoofer(feels like it if actually not) under passenger seat that gives good bass. Does the ML audio system have one?
thanks.
Old Jul 24, 2018 | 07:52 PM
  #269
richard203's Avatar
richard203
I mean when I use waze on my phone and I want to listen to the radio in the car the phone have no sound, I have to manually disable the Bluetooth on my phone to have back the sound on my phone. I never had this problem on my gs.
Old Jul 24, 2018 | 08:47 PM
  #270
gadgetman1's Avatar
gadgetman1
Huh? Use your USB cord plugged into the console & turn the Bluetooth off.
I can run both music & maps on my phone thru the car infotainment system. It interrupts the music for directions & goes back to music. I guess I don’t understand what you are trying to do or not do.
