Anyone can help me find this part? Rx350 sport 2020
thanks! I've been searching but can't find it as easily as I thought I would or any ideas popping it back in there permanently. Strip came off during dry blower in car wash, smh.
Is that the underside of the roof rail? I'm not sure how you managed to peel it back so much since I think its secured from the inside the car, behind the headliner...
I found this link that has a better representation of what it looks like but you might need to remove the anchor (the piece you see attached to the roof), reattached it to the rail and then secure it back to the roof.
Mine didn't come with roof rails just a rubber strip as you see pictured.....Honestly, I have no idea how it was "glued "or placed into the car, but almost the whole strip came up to the other side. I'm pretty sure it wasn't bolted in or anything like that....It seems to me whatever had it stuck to that anchor came off because it didn't on the other side. Maybe it was "glued" or stuck in some way to that anchor, but I can't get it to go back to a secured spot anymore, it just flops out. I can't seem to find the same part online (rubber strip). Honestly, I rather have the rail system, but it looks to me that it would be a custom job since, other than those anchors, there are no holes or anything like that to make that system you sent me via link be "plug and play"......
