Noise coming from passenger side engine
Old Mar 16, 2026 | 05:11 PM
Candrews86's Avatar
Candrews86
4th Gear
Default Noise coming from passenger side engine
Hey guys,
Got a noise coming from the passenger side of the engine well. Any ideas? Drives fine, but afraid to drive it too much without knowing.
appreciate any insight here.
Thanks
File Type: mov
Old Mar 16, 2026 | 05:17 PM
Best guess is rattling water pump a common problem on these engines.
Old Mar 17, 2026 | 09:01 AM
Clutchless's Avatar
Clutchless
I agree that it sounds like a failing water pump and this is not uncommon on these engines. It failed on my Sienna (same engine) at only 37,000 miles.
How many miles are on your RX? What model year?
The repair cost at an independent shop was around $1,100 with new coolant, and a new serpentine belt. Depending on mileage they may want to replace the belt tensioner and idler pulleys etc.
The cost will vary depending on where you live and where you take it to be repaired. It is about a 5 hour job.
Old Mar 17, 2026 | 09:09 AM
evident's Avatar
evident
100% water pump failure. You might be able to drive it a little longer short distances but dont try to go anywhere far with it. check and see how bad its leaking, and see my thread for all the fun i'm having doing this on my car.
I suspect water pumps fail on this car due to the coolant not being replaced enough but at the end of the day it's a known wear item on these engines.
Old Mar 17, 2026 | 09:13 AM
Candrews86's Avatar
Candrews86
4th Gear
It is a 2017 with 145k miles on it
Old Mar 30, 2026 | 05:56 AM
Candrews86's Avatar
Candrews86
4th Gear
Just as a follow up, took to my Lexus mechanic and it was in fact the water pump. Thanks guys
Old Mar 30, 2026 | 06:01 AM
Quantum501's Avatar
Quantum501
Thanks for the follow up. Always nice to see/hear the video and then get the correct diagnosis. Helpful to other members who may have same sound/issue.
Curious what the cost for the repair will be.
Good luck with the repair.
Old Mar 30, 2026 | 06:11 AM
Candrews86's Avatar
Candrews86
4th Gear
$350 for the water pump/parts. $1400 for labor
Old Mar 30, 2026 | 03:28 PM
GS4_Fiend's Avatar
GS4_Fiend
They are not removing the engine. Really should be a 2-3 hours job for labor.
Old Apr 1, 2026 | 01:09 PM
evident's Avatar
evident
man Ive done this job 2 times already and if i was a shop I would charge at least 5 or 6 hours to not screw myself over maybe even 8. It is a really shitty job esp to do it right 300 parts 1400 labor seems more than fair imo especially if they are replacing the belt and tstat while in there
Old Apr 1, 2026 | 08:34 PM
GS4_Fiend's Avatar
GS4_Fiend
Originally Posted by evident;[url=tel:12053398
12053398[/url]]man Ive done this job 2 times already and if i was a shop I would charge at least 5 or 6 hours to not screw myself over maybe even 8. It is a really shitty job esp to do it right 300 parts 1400 labor seems more than fair imo especially if they are replacing the belt and tstat while in there
You have the hybrid variant so the configuration is slightly different from what I see.
Old Apr 24, 2026 | 05:50 AM
lexflana's Avatar
lexflana
Hey guys,
Thanks
Great...now I know what it sounds like. Thanks for posting. We have a 2015, as well as the 2019, and waterpump was leaking around 150K, so that is about the service life of these, but as I understand, on the 2015 3rd gen, the newly designed waterpump (you get this when you replace your original) will last a LONG time. Not sure what the deal is on the 4th gen.
lextoys
LX - 4th Gen (2022-present)
61
Nov 9, 2024 02:01 PM
Carlito111
Suspension and Brakes
Nov 11, 2020 03:06 PM
Meego
Jul 29, 2010 08:27 PM
LS460Lover
Nov 6, 2009 09:41 AM
