Water pump replacement
Old May 26, 2025 | 01:58 PM
mrmonster's Avatar
mrmonster
Default Water pump replacement
So my water pump is making a noticeable rumbling sounding like the bearing is going. Looking at what parts I need to order and see 2 different options for the water pump. This is for a 2017 FSport with 186k km (116k miles).
1610009690
Exc.Japan Built. Incl.Gasket. Includes: Gasket. Includes: Water Pump Gasket. Main Engine Water Pump. Part has related component that cannot be reused/ reinstalled; gasket. Part has related component that cannot be reused/reinstalled; gasket. Part has related components that cannot be reused/reinstalled; gasket.
1610039616
Engine Water Pump.
Exc.Japan Built. From 04/2020. From 10/2017. From 11/2017. Incl.Gasket. Includes: Gasket. Includes: Water Pump Gasket. Japan Built. Main Engine Water Pump. Part has related component that cannot be reused/ reinstalled; gasket. Part has related component that cannot be reused/reinstalled; gasket. To 04/2020.
The date on my door jamb says "06/17" does that mean I should order 1610009690?
Also, any other parts required for this job? Description says it comes with the gasket, I just want to be sure I have everything when I take this apart.
Anything else to replace in that area when I'm there?
Thanks
Old May 27, 2025 | 02:56 AM
toyotaman7's Avatar
toyotaman7
Ask the dealer to pull the part number associated with your VIN.
Old May 27, 2025 | 08:16 AM
supratreo's Avatar
supratreo
from what i can remember off the top of my head you would need a water pump and 2 gal of coolant. it would also be a good idea to change the t-stat while your at it.
Aisin WPT808 Comes with gasket
Aisin THT024
Bando Belt 6PK1560
all can be found on rock auto along with coolant of your choice.
you can call the dealer about the PNs you posted but i wouldn't be surprised if they superseded to 1 number.
Old May 27, 2025 | 01:09 PM
mrmonster's Avatar
mrmonster
Yeah I ordered the WPT808 from rockauto yesterday along with thermostat oring.
Old May 29, 2025 | 07:19 AM
mrmonster's Avatar
mrmonster
Will these motors purge any air bubbles in the cooling system on their own with just keeping the coolant bottle full?
Old May 29, 2025 | 09:33 AM
supratreo's Avatar
supratreo
i wouldn't risk it. your introducing a lot of air into the cooling system by removing the WP. get a spill-free style funnel and bleed it with the heater valve open.
Old May 29, 2025 | 01:02 PM
mrmonster's Avatar
mrmonster
More info?
richard203's Avatar
richard203
wheres the heater valve located?
Old May 29, 2025 | 01:18 PM
supratreo's Avatar
supratreo
just turn the heater all the way up while its running. that opens the valve.
Old May 29, 2025 | 01:25 PM
mrmonster's Avatar
mrmonster
Lol you made it sound like it's some physical valve in the cooling system you have to open.
I think I'll just top off the rad and overflow bottle and let it go through few heat cycles monitoring/topping off the overflow bottle.
Here is the official procedure I belive:
  • Bleed air:
    • Turn A/C off.
    • Adjust heater control to max setting.
    • Adjust blower speed to low setting.
    • Warm up engine until the thermostat opens, circulate coolant for several minutes.
    • Maintain engine speed at 2500-3000 rpm.
    • Squeeze No. 1 and No. 2 radiator hoses several times by hand to bleed air.
    • Observe coolant levels and refill as needed in both the radiator and puke tank.
    • Stop engine, let cool, and recheck.
Old May 29, 2025 | 01:50 PM
richard203's Avatar
richard203
  • Bleed air:
    • Turn A/C off.
there is a bleeder valve.
Old May 29, 2025 | 02:13 PM
supratreo's Avatar
supratreo
the bleeder valve will make make it much quicker process but not all models have them for some reason. my 18 doesn't.
with the funnel its a 10-15 min process max and you don't risk overheating your motor.
Old May 29, 2025 | 05:04 PM
jcg0324's Avatar
jcg0324
The Lexus models with the 2GR-FKS engines unfortunately do not have a coolant bleeder valve. This would include the 4th generation RX models.
Old May 29, 2025 | 05:36 PM
supratreo's Avatar
supratreo
good to know. its not just me then lol.
Old May 30, 2025 | 08:18 AM
mrmonster's Avatar
mrmonster
Original vs "aftermarket", they grinded off TOYOTA from the aftermarket
It takes some effort getting to this thing. Not sure how much dealers/shops charge for this job but it would be a good number of labor hours.
