Automatic rear door doesn't work
Old Dec 19, 2021 | 04:56 AM
stamy74's Avatar
stamy74
Default Automatic rear door doesn't work
Hi there.
Today the automatic rear door mechanism stopped working. Recently I have noticed that when I was pressing the rear door close button, door was closing half way, stopping and opening again. Today it just stopped working. I cannot open it from the related button on the dashboard and I cannot close it from the rear door close button. The button on the glovebox is ON, anyway I pressed it several times in OFF/ON position just to be sure.
Any hints what it might be? Could be related to the cold weather (temperatures close and a bit below zero these days), although is the first time I face this issue? Car is a 2010 RX450h, so many cold winters in its back already. I replaced 12V battery and rear door gas struts a year ago, both OEM not original Lexus.
You can see the exact issue in the following 2 YouTube links:
Old Dec 20, 2021 | 04:03 AM
Clutchless's Avatar
Clutchless
Do a search using the term hatch as that is what we call the rear door.
There have been a few rear hatch motor failures discussed in this forum so be prepared.
Old Dec 20, 2021 | 04:07 AM
stamy74's Avatar
stamy74
Hi,
Seems like it was just a cold temperature issue. I opened the door manually with a bit of force and now works fine. Probably the gas struts were a bit too tough with the cold and needed to warm up a bit I followed the advise of some guys where I live, who had the same experience with NXs.
Old Dec 21, 2021 | 07:55 PM
stamy74's Avatar
stamy74
Actually it works only when interior of the car is warm. So either gas struts or power motor issue. I will further check.
Old Dec 22, 2021 | 06:50 AM
Clutchless's Avatar
Clutchless
Cheaper and easier to replace your struts again as I suspect they are more likely than your motor given the temperature effect on performance.
Cold weather usually shows the weakness in hatch struts, especially cheap aftermarket ones.
Old Dec 22, 2021 | 07:28 AM
RX in NC's Avatar
RX in NC
Some of the best hood and tailgate struts on the market are made by StrongArm. I put a pair of them on the hood of my wife's 2015 RX350 in October 2019. Much more robust than the factory hood struts were. If and when the factory tailgate struts begin to get weak, I will replace them with the appropriate StrongArm struts.
Old Dec 22, 2021 | 12:28 PM
Clutchless's Avatar
Clutchless
This site sells Strong Arm hatch struts ( I have them on my RX) and they will ship internationally.
https://www.liftsupportsdepot.com/ye...ILITY%204-DOOR
Old Dec 22, 2021 | 12:57 PM
stamy74's Avatar
stamy74
I live in Romania, so I don't know how I could purchase these. But thanx a lot for the advice, I also believe is a strut related problem.
Old Dec 22, 2021 | 03:25 PM
Clutchless's Avatar
Clutchless
Lift Support Depot linked above will ship to Romania.
ericw12
RX - 3rd Gen (2010-2015)
Oct 29, 2023 12:07 PM
fleury777
RX - 4th Gen (2016-2022)
Feb 16, 2021 07:48 PM
jbourne4
LX - 3rd Gen (2008-2021)
Sep 7, 2018 01:01 PM
Luap
Feb 4, 2018 09:10 AM
09lx570CC
Sep 3, 2008 03:08 AM
