which fuse is for MAF sensor
Old Oct 9, 2021 | 07:57 PM
origphoto's Avatar
origphoto
9th Gear
Default which fuse is for MAF sensor
I have 2015 rx350 and I just did throttle cleaning, but I did not attach hose tightly so later when I drove hose loose from air filter size that cause engine check light on. After I got home, I fixed loose hose, but I still got p0102 and p0171/p0174 code. After I tried to drive a couple of time, p0171/p0174 code cleaned, but p0102 still exist. Today I tried to clean MAF sensor again, and check harness voltage, than I found that there were no voltage at all, I tested position #3 and #1, they should be 11-14v, and 5v, but there were 0. than I restarted car and check the code, this time I have p0102 and p0113. so my question is , if there is MAF sensor fuse, if so which one? I check lexus rx350 2010-2015 fuse diagram, but can not figure out which one is. Also, if p0113 was caused by p0102?
Old Oct 10, 2021 | 08:03 AM
origphoto's Avatar
origphoto
9th Gear
after read 2010 Lexus GS 350 RWD V6-3.5L (2GR-FSE) Copyright © 2013, ALLDATA 10.52SS Page 1 A L L Diagnostic Trouble Codes ( DTC), it indicates :
(c) Measure the voltage according to the value(s) in the table below.
Standard voltage:
(d) Reconnect the MAF meter connector.
"NG -- REPAIR OR REPLACE HARNESS OR CONNECTOR (MASS AIR FLOW METER - EFI MAIN RELAY)"
where is the location of EFI MAIN RELAY? I did check fuses of #16 EFI MAIN, #33 EFI NO. 1, #39 EFI NO. 2, all are good.
Old Oct 10, 2021 | 01:22 PM
Clutchless's Avatar
Clutchless
Did you look at the fuse box in the engine compartment? It is on the driver side.
Old Oct 10, 2021 | 02:51 PM
afpj's Avatar
afpj
Cleaning the MAF sensor is a pain, have to remove the wiper cowl to get at the screws to remove. Are you using specific MAF cleaner, and did you unplug the MAF sensor before cleaning?
Old Oct 10, 2021 | 02:52 PM
origphoto's Avatar
origphoto
9th Gear
I did look at the fuse in Engine compartment, I found all fuses and relays are good, I did mistake at first when I measure voltage. Now I did recheck and I can get
1, 12 V , #3 to ground, also #3 to #2 (negative probe)
2, 5V , #1 to ground , also #1 to #2
so looks power supply has no issue, now I try to following to measure resistance of MAF to ECM, my problem is now I can not find E6 ECM connector
Old Oct 10, 2021 | 04:05 PM
origphoto's Avatar
origphoto
9th Gear
I did use MAF sensor cleaner to clean it a couple time, My techstream is too old to work on this lexus, but I have Bluedriver, and I followed up following document as:
"2010 Lexus GS 350 RWD V6-3.5L (2GR-FSE) A L L Diagnostic Trouble Codes ( DTC ): P Code Charts - P0102"
- Connect the Techstream to the DLC3. [I user BlueDriver]
- Turn the engine switch on (IG) and turn the Techstream on.
- Clear the DTCs (even if no DTCs are stored, perform the clear DTC procedure). [I did clear all pending and confirmed trouble code, but it has permenant trouble codes could not be cleared]
- Turn the engine switch off and wait for at least 30 seconds.
- Turn the engine switch on (IG) and turn the Techstream on [A].
- Start the engine.
- Idle the engine for 5 seconds [B].
- Enter the following menus: Powertrain / Engine / Trouble Codes / Pending [C].
- Read the Pending DTCs. [I did not see pending DTCs]
- If a pending DTC is output, the system is malfunctioning.
- If a pending DTC is not output, perform the following procedure.
- Run the engine at an engine speed of 4000 rpm or more for 5 seconds [D].
- Enter the following menus: Powertrain / Engine / Trouble Codes / Pending [E].
- Read the Pending DTCs.[I did not see pending DTCs]
HINT
Enter the following menus: Powertrain / Engine / Utility / All Readiness.
- Input the DTC: P0102 or P0103.
- Check the DTC judgment result
Since BlueDriver has not function of DTC judgement, So I can not perform this step.
so far I got:
1, MAF sensor Harness test is good, (12v, 5v and ground, not test connection to ECM)
2, I can see Mass Air Flow rate reading and it is proportional to engine rpm, when engine is idle , it is around 5-7g/s (seem MAF sensor works)
3, but Fuel system Status shows: System A (B) Closed loop - using all oxygen sensor(s) as feedback for fuel control
TuscaniLuv
Oct 26, 2022 04:37 PM
coug66
Aug 17, 2019 10:27 PM
b2884987
RX - 1st Gen (1999-2003)
Jul 4, 2016 08:26 AM
richonline
Nov 11, 2010 05:11 PM
her99rx300
13
Jun 21, 2006 10:19 AM
