AWD mode is activated
Old Jan 20, 2019 | 07:12 PM
fsport113's Avatar
fsport113
Exclamation AWD mode is activated
22015 RX 350 F-SPORT:
At start activating the AWD drive button, dashboard lighted on AWD mode is activated and working, as you drive along I noticed the AWD light dissapear as yOU reach the 50kph speed, as you stop you can activate again the AWD button and see light on the dashboard. Is this normal for type of vehicle?
Old Jan 21, 2019 | 04:51 AM
lexuscanuk's Avatar
lexuscanuk
Its normal. After about 40 km/h the awd looses its effectiveness (for the purposes that most of us use the awd) so Lexus decided to design it like this Plus it saves fuel at front wheel drive configuration.
It also switches on automatically if it detects wheel spin at the front if speeds are less than 40 km/h.
Old Jan 21, 2019 | 06:32 AM
Non's Avatar
Non
From what I understand, the button turns on the "AWD Lock mode" and it's meant to be used when you get stuck in mud or deep snow, not for regular driving.
The manual says that the "AWD Lock mode" sends maximum power to the rear wheels, which I assume is 50% of the engine power.
Your AWD is active all the time and you can not turn it off, but the computer decides when to send power to which wheel.
You can try turning on the "Snow Mode", I use it when it snows and the car has excellent traction!
Old Jan 21, 2019 | 07:11 AM
vlad_a's Avatar
vlad_a
As stated above, AWD is automatic and no need to turn anything on. AWD "lock" will try act like a 4x4, but will soon disengage as it is not suitable for continuous driving.
taleh
RX - 3rd Gen (2010-2015)
48
May 13, 2024 08:11 AM
jwigley
28
Dec 21, 2014 09:42 AM
vipros
18
Dec 16, 2010 05:15 PM
SaintNexus
Oct 18, 2010 09:12 AM
gentoo
Hybrid Technology
May 20, 2008 09:52 AM
