2010 RX - Engine drone
Old Apr 21, 2018 | 10:24 AM
charleston's Avatar
charleston
Default 2010 RX - Engine drone
hello
2010 RX350, 133k Miles. Dealer serviced
has an engine drone around 16-1800 rpms. Any ideas? Engine mounts?
Thanks!
Old Apr 22, 2018 | 05:58 AM
RealWing's Avatar
RealWing
Originally Posted by charleston
hello
Thanks!
just do a search. Many many exhaust vibration problems over many years. No Lexus fix for our 3rd gen. but they just issued a (partial) fix for 4th gen.
I fixed mine by adding a couple of dampers on cat converter
Jim
Old Apr 22, 2018 | 11:32 AM
charleston's Avatar
charleston
Thanks Jim
I am fairly certain the noise is more intake related//sounding vs exhaust, but I will do some more research
Old May 2, 2018 | 04:58 AM
draco's Avatar
draco
Jim
Can you show some pics of the work you had done. I get the drone on and off.
Old May 2, 2018 | 08:25 AM
RealWing's Avatar
RealWing
I bought two vibration dampers p/n 17581-31010 (There are some other numbers available as well), removed the fibre washers at the bolt holes and used two 2-1/2" muffler clamps (with 3/8" u bolts) to clamp to the exhaust pipe at each end of the cat converter.
Old May 5, 2018 | 04:26 AM
draco's Avatar
draco
Looks like an easy install. What I would like to know though is how does doing this on the catalytic converter stop the engine drone? They are vibration dampers and I am not sure how the drone is associated with the vibration.
Old May 5, 2018 | 06:37 AM
RealWing's Avatar
RealWing
My drone was most evident at abt 1600 rpm. This was right at my cruising speed of 100 km/hr. Very annoying. I could feel the vibration in the passenger inboard seatbelt. That led me to look under the car and that revealed that the cat exhaust hanger is bolted to the floor in the same location. Thus it was pretty obvious the vibration was coming from this location. Without getting into a long engineering description, the root cause was that the cat converter section was vibrating at its natural frequence at abt 1600 rpm. Thus the solution was to add dampers to prevent it vibrating so much at this point.
Jim.
Ps. The supposed Lexus fix for the 4th generation RX was a new cat converter section with 1 damper. Seems to be partially effective for those owners. Their exhaust is a different design than ours but had the same or worse drone problem.
Old May 12, 2018 | 12:15 AM
draco's Avatar
draco
My engine / exhaust drone seems to be more evident around the 1500 - 1750 mark (given the markers on the tachometer). I suspect then that the (from what I have read) the harmonics at that level seem to be the main problem. I just have to go find these parts now and then install the things and see what difference it makes. Looks like a fairly quick install and fix.
Old May 12, 2021 | 09:43 AM
Rapidxc's Avatar
Rapidxc
Jim.
Hi,
I have the EXACT same issue on my 2013 venza. The exhaust drones under light acceleration and there is no TSB. I will try installing 2 dampers on either side of the catalytic converter. The sound is so annoying and I cannot take this anymore!!
Joe G
RX - 3rd Gen (2010-2015)
18
Aug 19, 2022 05:11 AM
satnav
RX - 4th Gen (2016-2022)
Jul 22, 2016 12:33 PM
hmt
Mar 16, 2015 07:29 AM
dmccombs
Oct 24, 2013 06:04 PM
VTHiker
13
Apr 3, 2010 11:00 AM
