Options Installed.
Old Jan 12, 2018 | 11:00 AM
shoester's Avatar
shoester
Default Options Installed.
Hello,
I have a 2010 RX350. Vin:2T2BK1BA2AC050352.
I am trying to find out if my vehicle has a tow package?
Thanks, Gary Shumate
Old Jan 12, 2018 | 11:15 AM
Clutchless's Avatar
Clutchless
The easiest way is to Look inside the driver side wheel well or fender. It helps to turn your tires to the right first. If, at the front end, there are some vent slits, then you have it. Those are air vents for the transmission cooler which is part of the package. This has been asked many times and someone has posted a photo in one of the threads.
Old Jan 12, 2018 | 11:23 AM
shoester's Avatar
shoester
Default Tow Pkg
Thanks,
I was alittle confused after someone posted they had the vents and didn’t have the tow pkg?
Old Jan 12, 2018 | 01:33 PM
Clutchless's Avatar
Clutchless
I think they had a hybrid.
A tow package also has an extra oil cooler.
You could also look for the oil cooler hoses next to the oil filter. Originally they were rubber, but due to failures, Lexus provided an almost useless extended warranty plus free replacement if they leak. However, when they leak they usually burst on the highway, all your oil squirts out and you have a seized engine before you know what has happened. They have replaced them with metal pipes which you can buy and have a shop install or do it yourself if really handy. Here are photos
https://www.google.com/search?q=lexus+rx350+oil+cooler+hose&rlz=1C1GCEA_enUS778US778&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj1tPjNr9PYAhWGvbwKHa9oC-UQ_AUICygC&biw=1920&bih=949
Or check your VIN which should indicate if you have the tow package
Old Jan 12, 2018 | 04:20 PM
shoester's Avatar
shoester
Default Tow Package
I asked Lexus to send me a build sheet on my Rx350 and in 3 hours i had it. If you are in doubt about your cars equipment get it from the people who built it. Fortunately mine did have a factory installed (TO) tow package. Thanks to the forum members for their help!
Old Jan 12, 2018 | 07:10 PM
Clutchless's Avatar
Clutchless
Glad you confirmed it. Now get those rubber oil cooler hoses replaced before they break!
Old Jan 12, 2018 | 07:31 PM
shoester's Avatar
shoester
Default Tow pkg
Thats’s on my list. But it looks like to me they won’t replace them unless they are leaking.
I saw Lexus provided a secondary warranty for the hose leaking. It’s not a recall. Any thoughts?
Thanks
Old Jan 12, 2018 | 07:33 PM
shoester's Avatar
shoester
Default opps
My bad. I see you already knew that.
Thanks for the advice.
Old Jan 14, 2018 | 02:29 PM
Clutchless's Avatar
Clutchless
You have to pay for it yourself. It is under a couple hundred bucks if done by an independent Toyota/Lexus shop. The Highlander had the same problem. Any Japanese car specialist can replace that hose with the pipe. The only trick is you have to remove the studs in addition to the nuts to remove and replace it.
F250
RX - 3rd Gen (2010-2015)
Oct 17, 2016 09:04 AM
cless
Jul 19, 2014 04:05 AM
tsslaporte
Sep 30, 2013 06:29 PM
JohnsRX
RX - 1st Gen (1999-2003)
Aug 2, 2005 12:14 AM
PortAh
Sep 4, 2002 04:44 PM
